Recommendations for shop for trailer repair - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » Recommendations for shop for trailer repair
Old 04-04-2019, 07:21 PM
jhsmith's Avatar
jhsmith jhsmith is offline
jhsmith
Default Recommendations for shop for trailer repair
Time to change the brake backing plates on my '98 Trailex. 21 years of rust makes them too hard to work on. I've already spent 2 days on other trailer gremlins so I'm ready to send it to a shop. Any recommendations for trailer repair in Northern Virignina? Or do I take it west towards Leesburg and Summit Point?
Jim
White '91 SSM Miata #01
Yellow '19 718 Boxster (Wife's)
Black '15 GMC Yukon XL w/ '98 Trailex (Tow Vehicle)
Orange/Brown-ish '75 FJ40 (in case I run out of other car projects)
Old 04-04-2019, 07:42 PM
Modian's Avatar
Modian Modian is offline
Modian
I’ve heard good things about American Truck and Trailer near me. I’m going to give them a shot soon to bring my tire rack up to date so it can actually fit 18s and maybe upgrade the wiring.
I’m open to other places though.
Aaron
1993 964
2017 M3
Old 04-04-2019, 09:06 PM
Der ABT's Avatar
Der ABT Der ABT is offline
Der ABT
Heard good things about Restless wheels in manassas
Behe usually works on mine for things i dont want to do
Evan
87 911 E stock
GONE.......: 84 911 Estock
Website coming soon
Old
Old 04-04-2019, 09:31 PM
JoeG's Avatar
JoeG JoeG is offline
JoeG
Originally Posted by Modian View Post
Iíve heard good things about American Truck and Trailer near me. Iím going to give them a shot soon to bring my tire rack up to date so it can actually fit 18s and maybe upgrade the wiring.
Iím open to other places though.
Talk to the folks at Trailex. I went down this path for a CT-7541 based on forum recommendations about larger tires are better for various reasons but they said it was a waste of time and money. If you install larger wheels/tires there will be insufficient clearance so new brackets (see image) will need to be fabricated or sourced from Trailex to lift the wheel well. I learned the hard way.
Old 04-05-2019, 12:42 AM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
I think Aaron was talking about fitting 18s on his tire rack, right?
Rob T.
2006 Carrera S
1995 BMW 325is (Spec3)
2012 GMC Yukon XL Denali
Old 04-05-2019, 08:31 AM
Dandelion's Avatar
Dandelion
I had Trailer Care in Hamilton, VA work on my trailer during the off season, at the recommendation of Good Hands: https://www.yelp.com/biz/trailer-care-hamilton
I was satisfied with the job.
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 04-05-2019, 09:26 AM
Modian's Avatar
Modian
Yep. My tire rack was made when 15s and 16s were in vogue.
Aaron
1993 964
2017 M3
Old 04-05-2019, 09:49 AM
With a trailex I think you can simply loosen some nuts and slide the beams around is the T bolt slots Might be a bit more here and there depending
Old 04-05-2019, 10:28 AM
Building a Worm Hole.....
If you have a standard Trailex tire rack on the trailer, you can easily adjust the height of the tire center pipe, by loosening the 4 t-bolts holding the vertical squarish tube, and then sliding it up or down as necessary.
- 2000 Boxster S (the wife's)
- 1979 RX7 enduro
- 1986 944 (under new mgmt)
Old 04-05-2019, 10:57 AM
arob's Avatar
arob
Based on Tony's pic, it appears that you can "widen" the verticals too, correct?
Rob T.
2006 Carrera S
