e46 M3 - Service Engine Soon
Light popped up the other day and then magically went away. Came on again today and happened to have some time to pull some info. The software I have apparently is only in german, so need to figure out how to get the english version of that I suppose.
I'll be googling myself here shortly, but figured I'd toss this up here in case any of you are fluent in german and see something that stands out. E R R O R M E MO R Y R E P O R T ------------------------------------- Date: 06/29/18 22:59:05 ECU: MSS54DS0 JobStatus: OKAY Variant: MSS54DS0 ------------------------------------------------------------- RESULT: 4 errors in error memory ! ------------------------------------------------------------- 44 Signal aktiver Oelniveaugeber Error occured 1. times at: Error occured 2. times at: Error occured 3. times at: Error frequency : 52 Logistic counter: 40 Motordrehzahl 2480.00 1/min relative Fuellung 33.60 % Kuehlwassertemp. 81.00 Grad C Gesamtluftmasse 92.00 kg/h aufgetreten vor (rel. BZ) 15.40 h Motordrehzahl 2400.00 1/min relative Fuellung 52.00 % Kuehlwassertemp. 83.00 Grad C Gesamtluftmasse 136.00 kg/h aufgetreten vor (rel. BZ) 15.00 h Motordrehzahl 960.00 1/min relative Fuellung 20.00 % Kuehlwassertemp. 66.00 Grad C Gesamtluftmasse 20.00 kg/h aufgetreten vor (rel. BZ) 1.80 h 0100 - Leitungsbruch o. Wert fehlt Fehler momentan vorhanden sporadischer Fehler ------------------------------------------------------------- 105 Plausibilisierung Motortemperatur Error frequency : 1 Logistic counter: 2 Motordrehzahl 1120.00 1/min relative Fuellung 30.40 % Kuehlwassertemp. 41.00 Grad C Versorgungsspannung HR 13.70 V aufgetreten vor (rel. BZ) 14.10 h 1000 - Zustand/Wert unplausibel o. Uebertemperatur Fehler momentan nicht vorhanden sporadischer Fehler ------------------------------------------------------------- 13 Lambdasonde 1 vor Kat Error frequency : 11 Logistic counter: 38 Error occured 1. times at: Motordrehzahl 2800.00 1/min relative Fuellung 30.40 % Spg. Lambdasonde 1 v. Kat 448.00 mV Versorgungsspannung HR 13.80 V aufgetreten vor (rel. BZ) 32.50 h Error occured 2. times at: Error occured 3. times at: Motordrehzahl 880.00 1/min relative Fuellung 20.00 % Spg. Lambdasonde 1 v. Kat 456.00 mV Versorgungsspannung HR 13.80 V aufgetreten vor (rel. BZ) 28.80 h Motordrehzahl 3080.00 1/min relative Fuellung 44.00 % Spg. Lambdasonde 1 v. Kat 448.00 mV Versorgungsspannung HR 13.80 V aufgetreten vor (rel. BZ) 0.90 h 0100 - Leitungsbruch o. Wert fehlt Fehler momentan nicht vorhanden sporadischer Fehler ------------------------------------------------------------- 144 Lambdaregler 1 Error occured 1. times at: Error occured 2. times at: Error frequency : 2 Logistic counter: 39 Motordrehzahl 3080.00 1/min relative Fuellung 71.20 % Lambda-Regelfaktor 1 1.30 - Lambda-Adaptionsfaktor 1 0.98 - aufgetreten vor (rel. BZ) 0.70 h Motordrehzahl 3200.00 1/min relative Fuellung 29.60 % Lambda-Regelfaktor 1 1.30 - Lambda-Adaptionsfaktor 1 1.00 - aufgetreten vor (rel. BZ) 0.40 h Oberer Regleranschlag Fehler abgasrelevant OBD Fehler momentan nicht vorhanden sporadischer Fehler ================================================== ===========
Lane '93 RS America | '03 M3 | '02 325iT | |
------------------------------------- Date: 06/29/18 22:59:05 ECU: MSS54DS0 JobStatus: OK Variant: MSS54DS0 -------------------------------------------------- ----------- RESULT: 4 errors in error memory! -------------------------------------------------- ----------- 44 Signal active oil level sensor Error occured 1. times at: Error occured 2. times at: Error occured 3. times at: Error frequency: 52 Logistic counter: 40 Engine speed 2480.00 1 / min relative filling 33.60% COOLING WATER. 81.00 degrees C Total air mass 92.00 kg / h occurred before (rel. BZ) 15.40 h Engine speed 2400.00 1 / min relative filling 52.00% COOLING WATER. 83.00 degrees C Total air mass 136.00 kg / h occurred before (rel. BZ) 15.00 h Engine speed 960.00 1 / min relative filling 20.00% COOLING WATER. 66.00 degrees C Total air mass 20.00 kg / h occurred before (rel. BZ) 1.80 h 0100 - Line break or value is missing Error currently available sporadic mistake -------------------------------------------------- ----------- 105 Plausibility of engine temperature Error frequency: 1 Logistic counter: 2 Engine speed 1120.00 1 / min relative filling 30.40% COOLING WATER. 41.00 degrees C Supply voltage HR 13.70 V occurred before (rel. BZ) 14.10 h 1000 - State / value implausible or over temperature Error currently not available sporadic mistake -------------------------------------------------- ----------- 13 Lambda probe 1 before Cat Error frequency: 11 Logistic counter: 38 Error occured 1. times at: Engine speed 2800.00 1 / min relative filling 30.40% Spg. Lambda probe 1 v. Cat 448.00 mV Supply voltage HR 13.80 V occurred before (rel. BZ) 32.50 h Error occured 2. times at: Error occured 3. times at: Engine speed 880.00 1 / min relative filling 20.00% Spg. Lambda probe 1 v. Cat 456.00 mV Supply voltage HR 13.80 V occurred before (rel. BZ) 28.80 h Engine speed 3080.00 1 / min relative filling 44.00% Spg. Lambda probe 1 v. Cat 448.00 mV Supply voltage HR 13.80 V occurred before (rel. BZ) 0.90 h 0100 - Line break or value is missing Error currently not available sporadic mistake -------------------------------------------------- ----------- 144 Lambda controllers 1 Error occured 1. times at: Error occured 2. times at: Error frequency: 2 Logistic counter: 39 Engine speed 3080.00 1 / min relative filling 71.20% Lambda control factor 1 1.30 - Lambda adaptation factor 1 0.98 - occurred before (rel. BZ) 0.70 h Engine speed 3200.00 1 / min relative filling 29.60% Lambda control factor 1 1.30 - Lambda adaptation factor 1 1.00 - occurred before (rel. BZ) 0.40 h Upper governor stop Error exhaust relevant OBD Error currently not available sporadic mistake
“When I was born I was so ugly the doctor slapped my mother.” – Rodney Dangerfield Bill C "aka" Catdaddy - The Catfather - Current: 1980 911sc 2019 Ford Raptor 1987 Mercedes 560sl ------------ Sold: 2011 BMW M3 2000 996 C2-IMS 2 Row, RMS Update 1986.5 928s 1987 944 16v 1973 911t 1969 911t "My first car"!! 1969 Westfalia Bus 1973 Volks Superbeetle |
Thanks! Looking here to for clarification of some of these cryptic items
http://www.endtuning.com/bmwcodes.html 44 - Oil Level Signal Sensor 105 - Engine Coolant Temperature Implausible 13 - Lambda Sensor Signal Pre-Cat Bank 1 144 - Lambda Sensor Control Bank 1
