Any recommendations on brands/sources for exhaust hose? Is 3" the most common size?
Jim ------ "2017 Central PA SCCA Witch's Rallye - Best Team Costume Award" "2014 Central PA SCCA Witch's Rallye - Best Team Costume Award" White '91 SSM Miata #01 Green '96 911 (993) Carrera #409 Blue '09 911 (997.2) Carrera S Cab Yellow '19 718 Boxster (Wife's) Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle) Burnt Orange '75 FJ40 (Pandemic Project) Black '83 911SC Targa (regrettably sold when the second car seat didn't fit) |
Mine (got from Kurt) are about 5" - and you can borrow them if you'd like--I won't be using until at least September.
Peter (not "Pete") K. IndexFingerRacing.com 1992 Miata ("SSM") race car 2016 Toyota Highlander (wife's DD and my new tow vehicle 2017 VW GTI SE (DD) Gone and missed: 2009 911 C2S Coupe "The Green Car" 2004 Toyota Prius - sold to son's girlfriend 2006 Dodge Durango - sold to a Dorki 2003 Acura MDX - Just shy of 200K 86 Black 911 Coupe race car (owned 2010-2016) 86 Gold 911 Targa (owned 1998-2012) 82 WineRedMetallic 911 Targa (owned 1986-7) |
3 inch stuff works well. The key is how well it fits on the pipe. Too loose and you get gassed. Too tight and you can cook the hose adapter. Don’t let the hose sag at a sharp angle on the end of the pipe. You get a hot spot and more chance of back flow leakage. Keep the tube as straight as you an to promote flow. Done right the exhaust flow will draw in air around the adaptor.
http://vimeo.com/29896988 "There is grandeur in this view of life...." Darwin. The mountains are calling and I must go. You Matter. (Until you multiply yourself times the speed of light squared. Then you Energy) |
Huge thank you to John for passing along the set he got from Kurt.
And to illustrate how important it is to pay attention to exhaust.... I had backed my (new to me) '75 FJ40 up to the edge of the garage door with the door open and walked away to get some supplies BEFORE hooking up the exhaust hose. 10' x 9' open door, FJ40 tires inside the garage with the tail pipe just outside. In just 2 or 3 minutes, the carbon monoxide detector on the other side of the garage went off and indicated 700 ppm CO.
Enjoy it in good health! And let’s see some FJ pics!
'75 fj40
