Putting a 2 post lift in an old farm field - Page 3 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » Putting a 2 post lift in an old farm field
Old 07-23-2016, 02:29 PM
Compressors can live outside just fine if you take a couple of precautions. Only the compressor itself goes outside. Install the coalescing auto drain oil/water filter inside to protect them from freezing. Plumb the piping from the compressor to the filter downhill and the plumbing from the filter to the rest of the shop uphill. You want the water that condenses in the piping to drain to the filter. Plumb an auto blow down valve so the valve is 6 inches above the drain port. This way no water sits in the valve. Use a section flex air line between the tank and blow down valve and you are freeze proof.
Good advice. I need to figure this out too. 80 gal tank is great but takes up some space. I try to get noise down in general so if I stick it outside I still need to keep it quiet. Worst case building an insulated box around it seems like a good option. Obvious issue is keeping the heat down and maybe a snorkel to the fresh intake.
I put a switch/disconnect on the lift post, seems like a simple and cheap thing just in case.
Old 08-04-2016, 08:16 PM
edevinney's Avatar
Most Courteous Driver
edevinney
Ready for framing to start. The second floor deck will provide shade so that the slabs have their best chance not to crack.
Purcellville
993 + 951S + Boxster S + Eurovan MV + 4Runner
Old 08-04-2016, 11:52 PM
#polishforprez
In this weather I hope there was some form of moist curing in place for at least the first few days after the concrete was placed, if not for at least the full first week. Also, given the geometry, hopyfully the control joints were tooled/ cut in the same day to reduce the potential for shinkage cracks at inside corners.
Anyway, it's always good to see progress like that. A day or two of framing and it will really transform.
- 2019 quickly disappearing...
Old 08-05-2016, 12:23 AM
edevinney's Avatar
edevinney
Actually they won't pour until after that framing is done, for just the reasons you noted.
Purcellville
Old 08-05-2016, 12:34 AM
#polishforprez
Ah, can't tell from that pic. I thought there was already concrete, but I guess that is just gravel.Hopefully you are only ~ 2 months out from being complete enough to move in.
Old 08-22-2016, 08:21 PM
edevinney's Avatar
edevinney
Slow framing - its a bit complicated, to begin with, and not having a floor to build on caused some head-scratching. Then the floor system supplier sent slightly long joists, causing a delay to find a solution and make engineers happy. Situation Normal...
Purcellville
Old 08-22-2016, 10:42 PM
Mark Hubley's Avatar
Mark Hubley
I used this company for the installation of a two-post lift in my garage:
http://bandrassociates.com/
I'm very happy with the work they did. I purchased a used lift and hauled it to my garage. B&R did the install and charged me about $1,200.
2000 Carrera
2006 325i
2016 F-250
Formerly owned P-cars:
1987 924S
1999 Boxster
1986 944
Old 09-01-2016, 09:31 AM
edevinney's Avatar
edevinney
Good to know for installation, thanks.
More framing, and a look at the shop portion of the garage. Ceiling height should be about 11.5 feet, so I'm looking AT a Worth lift made to squeak under the ceiling (based on final, real measurement).
Purcellville
Old 09-13-2016, 06:06 PM
edevinney's Avatar
edevinney
Got a second floor, roof trusses, and sheathing. Hopefully the plumbers and electricians can get out next week to put the conduit and piping, and we can get floors poured.
Purcellville
Old 09-13-2016, 10:54 PM
911lnv87's Avatar
911lnv87 911lnv87 is offline
Freeloader
911lnv87
Nicely done ed!
Louis
1986 - 944 Turbo 2.8L - Graphite Metallic - DD
1988 - 944 n/a - 82K miles - Dark Blue - SOLD
1987 - 911 - Dark Blue - SOLD
