Porsche & BMW Cars For Sale/Wanted Post For Sale or WTB adds for Porsche & BMW cars here. Strictly moderated. |
FS: 2007 Porsche GT3 with 4.0 engine and much more!
Looking for a 997 GT3 with 4.0L engine and all the desirable track mods? This one is for you!
2007 Porsche GT3 4.0 Street & Track car Slate Gray 51,747 miles on odometer (full engine rebuild to 4.0L at 48K miles) No accidents. Clean CarFax report. Same owner since 2008. Asking price $109K Intro This 997 GT3 is everything a high performance/track enthusiast wants! The highly sought after combination of the mighty Porsche 4.0L water-cooled Mezger GT1-based engine paired with a well-equipped G50 gearbox, in a 997 chassis makes for a glorious driving experience on street and track. It takes years and $150K+ to evolve a bone stock car to this ultra high performance well-sorted form. It can be yours today. Engine 4.0L engine build by TPC Racing, completed on Oct 2018 at 48K miles. Have photo album to document the engine build. Build includes the following new parts: • Factory Porsche 997 GT3 engine block • Factory Porsche 997 GT3 RS 4.0 crankshaft(80.4mm stroke) • Pauter Chormoly alloy billet connecting rods • Factory Porsche 997 GT3 RS 4.0 pistons(102.7mm bore, 12.6:1 compression ratio), piston rings, liners • Factory Porsche 997 GT3 RS cylinder housings, Bank 1 & Bank 2 • Factory Porsche 997 GT3 RS oil pump • Factory Porsche 997 GT3 RS countershaft • Factory Porsche 997 GT3 RS crank pulley • Factory Porsche 997 GT3 RS main bearings, rod bearings, nose bearing • Factory Porsche timing chains, Bank 1 & Bank 2 • Factory Porsche chain tensioners, Bank 1 & Bank 2 • COBB Accessport with TPC custom dyno tune with 93/100 octane map(420/442whp) Other engine upgrades: • Factory Porsche 997 GT3 RS plenum and intake manifolds(installed prior to engine build) • Factory Porsche Motorsport GT3 Cup S exhaust cams(installed prior to engine build) • Factory Porsche Motorsport GT3 Cup air box(installed prior to engine build) • Coolant pipes pinned(installed prior to engine build) • Vario-cam actuators upgraded to larger M7 bolts • Factory Porsche Motorsport 997 GT3 Cup 200-cell cats • Factory Porsche Motorsport 997 GT3 Cup side muffler(installed prior to engine build) • Factory Porsche RS engine mounts(installed prior to engine build) Transmission Rebuilt by SSI Auto, 2019 at 49K miles. • Guard GT1 Chromoly alloy billet casing LSD with 40/60 ramps • Factory Porsche Motorsport 997 GT3 Cup 4.0:1 ring & pinion • Factory Porsche GT3 RS lightweight flywheel and clutch kit • Factory Porsche GT3 RS clutch fork, pivot shaft, slave cylinder • Cantrell Motorsport 85A polyurethane transmission mount bushing • Factory Porsche Motorsport 996 GT3 Cup shifter and cables Suspension & Brakes • DSC Sport 997.1 GT3 controller and DSC Sport 3-axis accelerometer • DSC Sport Tractive coilover kit with 500/800 lbs springs • TPC Racing adjustable 28.7mm front and 22.5mm rear sway bars • TPC Racing GT3 Cup-type monoball LCA, all four corners • TPC Racing monoball adjustable rear toe links with bumpsteer correction • TPC Racing monoball rear upper links • TPC Racing track/street suspension setup • Castrol SRF brake fluid with factory Porsche PCCB Body, Safety Equipment, Interior, Misc. • Factory Porsche Motorsport GT3 Cup front splitter(cosmetically blemished) • Factory Porsche Motorsport GT3 Cup front radiator grills • Factory Porsche Motorsport GT3 Cup strut front strut tower brace • Factory Porsche radiators, all three radiators and connecting hoses replaced • Demonspeed carbon fiber front dive planes • Getty Design GT3 Cup decklid and wing(decklid inside edge is blemished) • DAS Sport bolt-in roll bar, painted Porsche Speed Yellow • Racetech RT4009WHR seats • Racetech Pro 6-point harnesses(expires 2022) • Factory Porsche 991 Cup steering wheel and quick-release steering hub adapter • AIM MXS dash programmed for Porsche CAN data • AIM Smartcam with integrated data • Ecliptech shift light • Rennline aluminum floor mats and foot rest set • Rennline adjustable pedal set • Fire extinguisher bottle with bolt-on mount • Clear film protection on front end(installed in 2008, aging and blemished but still protects) • Valentine One radar detector • Rennline toe hook Wheels and Tires Comes with three set of wheels: • BBS Motorsport E88 3-piece 19x9.0 and 19x12, with 245/325 Michelin Pilot Sport 4S • Forgeline GA1R Monobloc 19x9.0 and 19x12, with 235/315 Hoosier R7 • Factory Porsche GT3 wheels, no tires • MSI Motorsport bullet-nose wheel studs • MSI Motorsport yellow Teflon coated lug nuts Includes Spare Parts And Notable items • Factory Porsche seats • Factory Porsche steering wheel • Factory Porsche GT3 RS 4.0 rear uprights(new in box) • Factory Porsche GT3 front splitter(new in box) • New windshield installed Notes Please be advised that this is not a pristine show car. It is a purposeful driver’s car that evokes pure pleasure driving car on street and on track. This car has never been in a car accident, but it does have minor rock chips from usage despite of the owner’s best effort having clear film installed. The exterior can be made pristine if so choose to with minor paint work but the clear film will need to be removed. Mechanically, this car is well-built, and well-maintained. Needs nothing. Engine, Suspension, and Maintenance work performed by TPC Racing. Clean CarFax report. Last edited by TomChan; 10-14-2020 at 02:18 PM. Reason: typo correction |
More pics.
Sold.
