Removing seats from a 981 Cayman - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Removing seats from a 981 Cayman
Old 10-13-2021, 09:07 PM
Default Removing seats from a 981 Cayman
How easy or hard is it to remove the seats from a 981 Cayman. I remember it was a total pain in my mid-80s 911s, but was easy-peasy in my 997.2. Would like DD with comfortable seats, but must have harnesses and HANS for the track. Still not sure what my next car will be...or when.
IndexFingerRacing.com
2016 Toyota Highlander (wife's DD and my new tow vehicle
2009 911 C2S Coupe "The Green Car"
2006 Dodge Durango - sold to a Dorki
2003 Acura MDX - Just shy of 200K
86 Black 911 Coupe race car (owned 2010-2016)
86 Gold 911 Targa (owned 1998-2012)
82 WineRedMetallic 911 Targa (owned 1986-7)
Old 10-14-2021, 07:23 AM
RV4Flyer's Avatar
RV4Flyer RV4Flyer is offline
RV4Flyer
Easy 4 bolts holding it down, just be sure you have the correct socket. Not sure what these types of bolts are called but pic below to see it. Depending on the seat electronics you'll need to disconnect everything from underneath the seat once off the floor. The airbag light will stay on after removal. I have had it cleared a couple times and it came back each time so I just live with it now.
Mike
14 981 Cayman S
Wall of Dearly Departed Loved Ones
07 987 Cayman S
03 996
86 944
74 914
78 924
Bro Code Rule 43:
When a Bro learns another Bro has been in a traffic accident, they must first ask what condition the car is in.
Old 10-14-2021, 02:33 PM
Otto's Avatar
Otto Otto is offline
Otto
it is either a 12 point head or a torx head
Otto
#906
2014 Cayman S
2012 Cayman S - retired
2006 Boxster S
Old 10-14-2021, 02:48 PM
Etorx - the new(ish) thing in German automotive fasteners. If you work on BMWs you have a set of these already, or you work on very old BMWs.
Old 10-14-2021, 04:00 PM
Nerfbar's Avatar
Nerfbar Nerfbar is offline
Nerfbar
The secret to the air bag light is to always have the ignition off when disconnecting the seat from the electronics. Removing the four bolts is easy but that removes the seat and the tracks. It's best to leave the seats with their tracks and have tracks fitted to the replacement seats. I used to do this with a small impact wrench in minutes.
Barry
18 Carrera cab
15 Macan S
Old 10-14-2021, 08:31 PM
trytryagain's Avatar
trytryagain
The only things I would add is that the OEM seats are freaking heavy so watch your back. Also, the seat belt receivers are connected to the OEM seats with multiple wires, sensors etc. If you want to use the three point belts while driving around you will need to add some receivers. I bolted in receivers from a 944, which did the job.
Jim C.
1971 914 (back in the day)
Old 10-14-2021, 09:59 PM
tomfree tomfree is offline
tomfree
^^^^^Has a set of etorx sockets, but currently doesn't own a BMW^^^^^
Tom Freeman
Coming soon '87 951 w/ LS |'21 Q5 PHEV (DD, dog hauler)
'16 Vulcan S
Old 10-14-2021, 10:01 PM
Thanks all. This sounds very do-able.
Old 10-15-2021, 11:09 AM
jerome951
Hey Peter,
I have the E torx bits if you need them..
Jerome Welte
'97 Spec Boxster
'15 Ford Fusion plug-in hybrid (DD)
'06 Toyota Tundra
Old 10-17-2021, 12:16 PM
tbernard's Avatar
tbernard tbernard is offline
tbernard
I used to do the seat swap with my 981CS. As already stated the electric seats are heavy, cover door sill's, etc.
Make sure you don't have the key in the ignition or turn it on when there's no seat. Otherwise you will end up with an airbag light. I used a 997 seat belt receptacle and it plugged right up with no air bag light.
A iCarsoft POR V2.0 can be used to clear the airbag light, durameteric will also work. Maybe others.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Todd
Ex rennlist moderator & Banned - want to see why www.notonrl.com
18 718 Cayman GTS (GT Silver)
18 GT3 (VG)
Gone
14 981 Cayman S (white)
15 991.1 GT3
11 997.2 GT3
96 993 Targa
96 993 C2 tracker
00 986 Boxster S
99 986 Boxster
