#41
The proud owner and his running car.
#42
Well done!
#43
What a great thread!
#44
Greetings:
I have been studying this thread with interest. With considerable trepidation I will be pulling the head from a 87 IS as there's bubbling gas in the expansion tank, and thus a steady stream of water out the overflow. I saw one mention of a recommended machine shop in VA, but given the thread dates from 2014, I wonder it's still relevant. Ditto parts sources. I'm also wondering about special tools needed such as ?VANOS adjuster? -- (Can I rent one somewhere?) Any input appreciated. |
#45
The machine shop is still there. Didn't realize any of the e30 engines had a vanos? Don't you have a timing belt? Is so then there is no vanos on the car. Only tool I borrowed was the valve spring compressor to remove the valves. If you don't want to do all of that yourself, you can give the shop a complete head and they will return a clean one back to you all ready to install. Cost a little more but I do lots of these things just to learn how and I have a basic rule that if I can do it myself I will..let me know if I can help answer any questions.
#46
Since I don't yet know what a VANOS is, I don't know if I have one or not. (I saw it mentioned in writeups on the job.)
[This is the biggest car job I've ever tackled alone; last head gasket job was on a Datsun 210 with pushrods.] Yes, I'd take the intact head to a recommended shop. |
#47
Vanos is a timing system installed on e36 engines starting about 94. Doubt you have one on yours unless you have a different engine. Plenty of procedures online for the head gasket replacement. Really wasn't that difficult. Take lots of pictures, label things clearly, and don't be in a rush.
#48
Just went back through the thread. On the machine shop...I used a shop in the manassas area. They are still there and have used them since. On boost also listed another shop which may be closer to you. One thing I would recommend is to have a second person to help pull the head off and put it back on when ready. It isn't that heavy but given the angle can be a bit difficult. Also make sure the crank shaft is correctly positioned prior to torquing head bolts. Was the one mistake I made.
#49
#50
Headgasket
