Wiring Question -996
I am in the middle of a project to clean up the wiring in the race car -remove all of the unnecessary wiring and organize and clean up everything else for easier access.
Trying to figure out how to remove unused wires from the fuse and relay panels. I cut them close to the back of the panels but prefer to remove the pins themselves to prevent any electrical issues. How do I get the pins to release from the panels? Did some googling but cant find the answer.
Not sure what connectors Porsche is using in the 996 fuse box, but you typically need to get a set of terminal extractors to push in the little clips that are holding the terminals into the box. Something like this:
https://www.amazon.com/Terminal-Remo...ZK531TRGVT3KPF or this: https://www.amazon.com/OTC-4461-6-Pi.../dp/B008PV8F30
so Chris I actually have a set like that - couldnt figure out exactly which side to push in to release.
The side with the catch tab.
So is that from the back or the front?
Sent from my iPhone using Tapatalk Pro
Pictures would help.
Ok I will take a couple when I get back in town tonorrow
It's the side with the wire attached. The clips prevent the lugs from pulling out the front. When you release the clip, you pull the lug out the front.
88 911 00 Boxster S (wife's ride, becoming mine too) Even duct tape can't fix stupid... but it can muffle the sound! |
I have the same extractors Jazz linked above. They work well even though they are inexpensive. I have attached a couple of pics showing the lugs of a JPT terminal that is used on several of the Bosch connectors and the tool used to release them. Not exactly what you are looking for but the Kompakt connectors release from the plug end.
I also purchased an Iwiss terminal tool from Amazon that works well. I did some practice runs with spare terminals...first couple didn't turn out great but after about 5 runs I got the feel of the tool and was able to make a great looking crimp.
Steve 996 GT3 996 C2 (gone) 911SC (gone) |
