Circular saw fix - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Circular saw fix
Old 08-03-2022, 10:23 PM
John Clay's Avatar
John Clay
Default Circular saw fix
I've had this Makita saw for probably 30+ years. The lever that locks the cut depth adjustment in place won't tighten down unless I rotate it 180 degrees clockwise from where it is sitting now. That doesn't do any good, because then the cut depth is zero.
Anyone have a clue how to fix this?
John Clay
2011 Cayman
1986 944 "Traffic Cone"
2013 Scion FR-S
Old 08-04-2022, 09:53 AM
Dandelion's Avatar
Dandelion
Hi John - I'm guessing that the locking mechanism has been goofed up since you've owned it?
A buddy of mine who does woodworking has the following to say:
"It’s an older mechanism, can’t really compare to my saw… I’ve seen some things about “re-clocking” the locking mechanism, but not sure how that would become a problem after 30 years. That fix is tied to bad assembly [at the factory] in the first place.
"So the re-clocking is that you remove the e-clip, remove the handle, rotate the mechanism then re-attach the handle. Can’t tell in the picture if an e-clip is used. "
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 08-04-2022, 11:28 AM
John,
Is there a grommet or bushing that may have deteriorated and fallen out that may have been what allowed tightening of the lever, without the bolt going all the way down.
- 2012 Cayman R (also the wife's)
Old 08-04-2022, 12:01 PM
ducatithunder's Avatar
ducatithunder
Ive had to swap bases on my old skil saw when the mag base broke. The thumb lock on mine is just captive to the nut that tightens the adjustment. You should be able to pull it apart reclock the thumb lock to where you you like. I would agree that a bushing/washer that rides along the rail may have been lost as the lock should move 90 Deg before it tightens.
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
17 Alfa Giulia Quadrifoglio
Projects
86 "Backdate" 911 2.8 RSR
73 911 T Targa (Sold)
Old 08-04-2022, 07:46 PM
turkis_tii's Avatar
turkis_tii turkis_tii is offline
turkis_tii
Lol, I ran into this same problem on my Mikita saw yesterday. It locks fine with higher angles, just not when at “0”. I’m going to put in a shimming washer (if I can get the nut off!) we’ll let you know if that works.
- John
‘00 Porsche 996 C2
'72 BMW 2002tii
'92 SCCA SSM (sold)
'80 SCCA SRF3 (sold)
'89 Porsche 944 (sold)
'59 Porsche 1600S (long gone)
Old 08-04-2022, 10:10 PM
It looks like you are missing the guide? See my saw - 810 mm Makita
Old 08-05-2022, 11:58 AM
Remove the small screw that holds the tear drop shaped plate. Turn the nut 1/6 rotation tighter. Reinstall the teardrop plate and screw.
Old 08-05-2022, 02:15 PM
John Clay's Avatar
John Clay
Run upstairs, fix my saw, eat some lunch, back to work. All in 15 minutes.
John Clay
2011 Cayman
2013 Scion FR-S
