TPMS and wheels - Dorkiphus.net
Old 11-26-2019, 04:45 PM
John Clay's Avatar
John Clay
Default TPMS and wheels
I picked up a set of OEM mini cooper wheels from a fellow autoxer over the weekend. When I got home, I looked up the part number and it showed it was for 2002 to 2008 models. Ours is a 2013. I researched a bit and I'm concerned they may not be usable due to tpms compatibility.
Anyone know how this all works?
He's got some after market wheels I could look at also. So if the OEM wheels won't work, is there something I should look for to see if the after market wheels are compatible?
John Clay
2011 Cayman
1986 944 "Traffic Cone"
2013 Scion FR-S
Old 11-26-2019, 06:18 PM
Hunt + VG 2020
Will the car not start/ run if the TPMS system is not working right? (hopefully not, that would be too much Big Brother)
- 2020 quickly disappearing...
Old 11-26-2019, 08:00 PM
Der ABT's Avatar
Der ABT Der ABT is offline
Der ABT
What kind of tpms?
Sensor in the wheel
Or
ABS based.
If sensor.....you can probably by spare sensors
If ABS...will just need to re zero
Evan
87 911 E stock
GONE.......: 84 911 Estock
Website coming soon
Old
Old 11-26-2019, 08:09 PM
John Clay's Avatar
John Clay
The new to me wheels are sitting in my basement waiting for spring to get closer. The question was if the tpms will be a problem when I get tires mounted.
John Clay
2011 Cayman
2013 Scion FR-S
Old 11-26-2019, 08:56 PM
Early mini's didnt have a tpms, used wheel speed variance. 2013 uses sensors in the wheels, you'll need to go through the learn process.
Old 11-27-2019, 08:11 AM
Building a Worm Hole.....
Wheel speed sensors are somewhat standardized. I believe there are variants of sensors that are part of the valve stem or mount to the inside of the wheel center, attached via a strap. If you want to use the sensors, I believe it should be possible to retrofit the older wheels. However, if the car doesn't go into some sort of limp-mode if sensors aren't detected, you should be able to use them if you can ignore the dash warning. For example, some Corvettes went into limp mode if sensors weren't detected; our 2007 Cayman only displays a message on the dash.
- 2012 Cayman R (also the wife's)
- 2000 Boxster S (the wife's)
- 1979 RX7 enduro
- 1986 944 (under new mgmt)
"Keep your eyes on the road and your hands upon the wheel." - The Doors
