My "new" E46 (1999 328i) - Page 19 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > BMW Technical Discussions » My "new" E46 (1999 328i)
Old 12-10-2018, 11:16 AM
I think he outsourced the work to BT
Old 12-10-2018, 12:21 PM
Since this thread is a couple years old, a quick recap:
In Jan 2016 my daughter got her license and needed a car to drive to school. My requirements for this car were (1) manual transmission and (2) I liked working on it. That led me to picking up this 1999 328i off Craigslist for $1300:
To be completely honest, I was really pretty naive when I got this. Known issues were: tires, brakes, windshield, rear dif bushing, and SES light cause (I presumed) by a broken MAF-to-throttle body boot. So maybe another $1500 in parts and for < $3k she'd have a solid, manual transmission car to drive. So I jumped in with both feet and ordered a lot of parts:
Rebuilt brakes:
Fixed cosmetic issues:
and test drove. Still had the SES light even after replacing the intake boots, and I knew the dif bushing was an issue. Looks like my inital cost estimates were off and the car was going to need more time and money. I was weary of diving in on this project with a car that had 220k on the clock, so I did a leakdown and compression test and the numbers were unbelievable:
Old 12-10-2018, 02:23 PM
Since the engine was strong, I figured the car was worth fixing (this point can be debated later). To address the SES light, I decided to replace all the rubber under the hood. I bought lots of things:
took everything apart:
and replace anything rubber under the hood:
- Rebuild the VANOS
- Replace cooling system: pump, thermostat, hardlines, rubber lines
- Replace CCV, injector seals, intake/valve cover gaskets
- Replace all rubber fuel lines and fuel pump
- Replace power steering lines
- Replace all vacuum lines and SAP hoses
With that done I decided to tackle the rear suspension bushings. You see in the first picks my car is parked on ramps over a low rise lift. Well, I'm over 40 so a low rise lift isn't cutting it for doing the rear end work, so I had a two post lift installed:
Pulled the rear suspension:
Replaced all the bushings:
Found some dreaded subframe cracking:
And welded in reinforcement:
So that's where this thread left off. Next up: final drive and rear suspension.
Old 12-10-2018, 07:35 PM
Thanks, Jazz. As always, a fine write-up!
IndexFingerRacing.com
Old 12-25-2018, 01:30 AM
Noah's Avatar
Noah Noah is offline
Noah has one HoF thread
Damn Chris. You hate free time. Nice going.
Old 12-25-2018, 01:04 PM
Tito
86911TLCAB
Great work. Never know what a project is going to cost. I always figure on 150 percent of my initial thoughts and then hope for the best.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
