Needed: Fender Roller - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Tools Needed/For Loan » Needed: Fender Roller
Tools Needed/For Loan If you need to borrow some tools, or have tools to loan, post here.
Old 11-05-2018, 11:50 AM
1970911 1970911 is offline
1970911
Default Needed: Fender Roller
Hi all,
George D. here if you know me from around the track. It appears I will be in need of a fender roller at some point in the future. Just curious if anyone near me has one. If I could come by and use it for a day that would be so great! If nobody does, I could just buy one on Amazon but I wanted to post here first.
Thanks for any help,
Dean
'70 911
'01 Gt3
'04 Gt3...gone
Old 11-05-2018, 02:31 PM
GT3's Avatar
GT3 GT3 is offline
GT3
Baseball bat or jack handle
Clarke
68 912
75 911S Gemini Blue 3.0L
10 GT3
18 S6
22 F250 King Ranch
Gone:
18 F250 King Ranch
12 F450 Lariat
11 GT3RS silver
11 GT3RS white
10 Cayenne GTS
08 Cayenne S
06 997 C4S cab
(2) 05 997S C2 Launch
04 M3 Laguna Seca Blue
02 996 cab
91 964 C4
82 911 SC Euro 3.0
(3) 78 911 - 3.2
77 911
75 911S
73.5 911T
73 911T
72 911T
71 911T RSR vintage racer 3.0
68 911
Old 11-05-2018, 02:45 PM
Chopper Dropper's Avatar
Chopper Dropper
Heat gun for a bit of heat and baseball bat gently.
Dirk
1988 911 Targa
1986 944
Old 11-05-2018, 05:54 PM
mlytle mlytle is offline
mlytle
I keep a baseball bat in the race trailer for emergency alterations, but...a real fender roller is SOOOOO much better and more discriminating than a bat. heat gun to get paint to 160deg, then gentle application with the roller.
i have Eastwood one, and a lift, if you don't find one closer than alexandria.
they are pretty cheap to buy.
Marshall
95 M3
97 M3
Old 11-06-2018, 12:54 PM
1970911
https://www.amazon.com/NEW-Eastwood-.../dp/B001D4CGO0
Thats what I've heard. We have always used a bat on the green car and it works, but its a little more tedious to do it right I reckon.
Thanks!
Dean
'70 911
'01 Gt3
'04 Gt3...gone
Old 11-06-2018, 02:52 PM
2 inch white pvc pipe works way better. Jack the car up and down to control the gap between the wheel and lip and angles as you walk the angle in. Clean the lip up inside and out to remove dirt and grit. Spray a light coat of silicone on the pvc to reduce friction.
I find this works better that the east wood roller. You have better ability to tune the angle throughout the well
Old 11-06-2018, 05:10 PM
Originally Posted by 1970911 View Post
Hi all,
George,
Is this for the M3 with that beautiful blue paint job? If so please post a picture or two.
Thanks,
Lucky owner of a couple of 911’s and another Porsche or two
Old 11-07-2018, 12:32 AM
1970911
Thanks Kurt,
I will give this method a shot. Sounds pretty well thought out.
Dean
'70 911
'01 Gt3
'04 Gt3...gone
Old 11-07-2018, 12:36 AM
1970911
Originally Posted by Patrick3000 View Post
George,
Thanks,
Hi Karl,
Thank you sir and that it is. I surprisingly don't have any real pictures... yet. I will get some photos up as soon as I am home for thanksgiving break.
Dean
'70 911
'01 Gt3
'04 Gt3...gone
Old 11-07-2018, 07:51 AM
mlytle
Thanks Kurt,
every artist likes their own brush, but...
be very careful using a pvc pipe. pvc is hard. paint is not. you will easily crack the paint if you don't keep it at the right temperature and keep the pressure light.
this is why i like the real fender rollers better. far more precise with the angle of roll and pressure, plus the actual roller is polyurethane which is softer on the paint.
critical in all cases (if you care what the paint on the car looks like) is keeping the paint temp up in the 160-180 range both inside and outside of the fender. heat gun and IR temp gauge need to be in constant use.
Marshall
95 M3
97 M3
