Plugged Tire at DE? - Page 3 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » Plugged Tire at DE?
Old 03-15-2018, 01:37 PM
Aaron Ambrosino Aaron Ambrosino is offline
Aaron Ambrosino
Is this a PCA De requirement?
If you are referring to the tire repair method mentioned in the above post, no it is not.
Aaron
Old 03-23-2018, 03:58 PM
RestonGuy RestonGuy is offline
RestonGuy
Just to close the loop here.
As a pilot and flight instructor, I always strive to reduce risk.
So in keeping with that goal, I bought a new tire and will keep the plugged one for street use only, if it is needed in the future.
John S,
2010 911 C2S (daily driver #1)
2009 Audi S5 (daily driver #2)
1979 Audi 4000 (gone)
1972 914-2 (gone)
1977 924 (gone)
And Others…..
Old 03-23-2018, 04:59 PM
Hunter's Avatar
Hunter Hunter is offline
Hunter
Well done sir. All of your peers on track appreciate you mitigating the risk.
Never complain about the cost of your rubber..............
90' 964, Red, Number 692 (Misty)
Trailex (Dusty)
Old 03-23-2018, 05:39 PM
Vicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threads
Funny thing...
The reason for the T plug format requirement is in large part to keep water from getting into the carcass and damaging the steel belting over time. This is not a track tire issue as they become worn out at a very accelerated rate. Plug, track scrub to the cords over a weekend is the safest format for a nail hole.
If you have any doubts about the tire repair discard the tire. DE is for fun and if you are thinking about a tire you are not thinking about fun.
Me? I am thinking about the 5672 nuts, bolts, con rods, struts, tubes,wires, connectors, pistons, rings, E-clips, push rods and all other parts that I selected and assembled to make up the machine I am in. Sucks to be a highly visual mechanic. No farking way would i get in my own helicopter. Choppers are trying to get back on the ground and not all on one chunk.....
http://vimeo.com/29896988203100watts
Keepers of the cog. Rule#5#10#43
Until you multiply yourself times the speed of light squared. Then you Energy.
Science, Please.
Old 03-24-2018, 12:23 AM
There's a lot in this thread that would be at home in the "new tool" thread! Topic is a fav and even a little search will produce lots of opinion. I'll go with what Paul says and he is an authorized Michelin man.
