FS: 2003 Audi Avant Quattro 3.0 - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Other Stuff For Sale » FS: 2003 Audi Avant Quattro 3.0
Old 04-06-2021, 10:04 AM
racer's Avatar
racer racer is offline
racer
Default FS: 2003 Audi Avant Quattro 3.0
https://dorkiphus.net/porsche/showthread.php?t=40393
This car is up for sale. It needs a little more work than I am interested in pursuing at this time.
What's been done since it was acquired last spring you ask?
Oil+Filter change in November 2020
Wiperblades (3)
New Audi key ($250 value right there!)
Drivers door window switch controller replaced (worked fine, just a cosmetic issue)
Steering wheel cover
Rear 3rd brake light / housing
Sunroof switch
Hatch and Hood struts
Cabin Filter
Haynes manual
Front control arms and ball joints
Timing belt service
Fan control module
What needs attention:
Washer fluid low level light is always on despite being full / sensor issue?
Power Steeering line leak
Possible coolant leak
Throwing codes:
1) P0420 - threshold issue, Bank 1? - could be just o2 sensors, or need a new cat
2) P0430 - threshold issue, Bank 2? - could be just o2 sentors, or need a new cat
3) P0700 - Transmission - not sure why, seems to drive ok
130,000 miles.
Silver over black.
Automatic (Tiptronic)
Quattro
3.0l V6
Price? Scrap value? $1500 o/b/o?
Starts, Stops, Turns... heat and AC work. Sunroof and windows all work. Radio works (yes, it still has its original cassette unit!)
Still has the rear cargo cover that provides both horizontal and vertical protection and coverage. Matching full size spare. Comes with
2 keys and Owners Manual too
If no interest, it will be found on CL with the "I know what I have here so don't low ball me" approach to vehicle sales
Or, it will simply be offered to that incessant "1877 Kars 4 Kidz" ad I keep hearing!
Since I am still not commuting with no change in site, Kid #1 will simply share my 13 year old DD.
PM or Email ( racer_d911 at hotmail.com) or text 703, nine, nine, nine, 4, zero, nine, 9
Dave
- 1970 914-6
- 1987 924S
- 2000 Boxster
- 1987 944
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 04-06-2021, 12:37 PM
Try posting on a local board:
https://forums.quattroworld.com/midatlantic/
Those error codes are common and annoying to hunt down. The cat codes could be anything from a cracked or clogged cat or bad o2 sensor. The transmission one on it's own is odd, usually it's that and another code for a torque converter or something.
I'm in the midst of the stupid SAI pump air flow codes on my car, super annoying and nearly impossible to hunt down.
'73 914 2.0 (2.7/6 conversion in progress)
'02 S6 Avant
'99.5 A4 2.8QT
'65 Falcon 80
Old 04-06-2021, 07:42 PM
racer's Avatar
racer
@jmuRiz.. Thanks for the advice on Quattroworld. Put the add on there too. Not sure if it in the right spot or overly visible, but its out there.
Dave
- 1970 914-6
- 1987 924S
- 2000 Boxster
- 1987 944
- 1978 911 Euro SC
- 1976 914 2.0
Old 04-06-2021, 10:00 PM
'02 S6 Avant
'99.5 A4 2.8QT
'65 Falcon 80
