Alternator assistance - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Alternator assistance
Old 03-05-2021, 09:34 AM
Tito
86911TLCAB
Default Alternator assistance
Need a little help understanding an alternator/ external radiator issue.
78 3.0 911 engine. External voltage regulator.
When running battery is not getting a charge.
Wiring appears to be all there and connected.
When I turn car to on the light on the dash illuminates. When running it stays on.
Alternator and vr are properly grounded.
I donít really understand where I should be checking for 13+ v to determine if issue is alternator or voltage regulator. Does alternator actually provide voltage to the vr which then regulates that to the car/battery. Where can I check to determine issue. Any help appreciated.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 03-05-2021, 11:57 AM
Basic process
start with a charged battery, ~12.6v. at ~2k rpm check voltage at battery, should be ~13.5-14.5v. Make sure regulator is grounded, clean. usually higher than 14.5v replace regulator, if lower than 13.5v test/replace alternator.
Old 03-05-2021, 12:02 PM
Building a Worm Hole.....
Many FLAPS have an alternator test bench. A good easy way, once removed from the car, to confirm that the alternator is outputting properly while its rotating. Most will test for free.
- 2000 Boxster S (the wife's)
- 1979 RX7 enduro
- 1986 944 (under new mgmt)
Old 03-05-2021, 12:10 PM
Good advice. For a 911 take the alternator in the fan housing as an assembly.
Old 03-05-2021, 12:20 PM
Look everything over too. You can inspect the connections and brushes . Many a bad alt was loose connections.
Old 03-05-2021, 12:25 PM
If you need a replacement, Arlington Armature may be a source for a rebuilt alternator.
http://www.starrad.com/home/3840084
18 GT3T -
11 997 C2S - Aerokit Cup
04 996 GT3 - HPDE
19 Beetle Conv - Hers
13 S60 T5 - Kids
08 535i 6 Spd - DD
01 Bullitt Mustang - Kids
Sold: 86 951, 14 911-50, 79 911SC, 74 914/6, 11 997.2 C2S, 88 944, 16 GT4, 13 Boxster, 1973 914/4 2.0, 1980 911SC ROW w/3.2, 77 911S Targa, 1970 914GT 3.2, 71 914/4 2.4, 76 912E, 89 944S2, 1980 924 Turbo, 98 Boxster, 70 911T, 72 914, 75 914, 73 914, 87 944, 74 911, 72 914 - 97 M3, 06 M3, 95 M3, 98 328is, 95 530i, 95 328is
Old 03-05-2021, 08:00 PM
Tito
86911TLCAB
When I run it the battery is leaking volts. I need to test at 2k rpm. I just did it at idle. So if not getting any increase in voltages at battery then alternator is the issue. It can’t be just the voltage regulator?
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 03-06-2021, 06:14 AM
Originally Posted by 86911TLCAB View Post
When I run it the battery is leaking volts. I need to test at 2k rpm. I just did it at idle. So if not getting any increase in voltages at battery then alternator is the issue. It canít be just the voltage regulator?
This is hard to understand well enough to reply to. It can just be the regulator. It can be tested too.
Old 03-06-2021, 10:10 AM
Tito
86911TLCAB
Ok. Sorry for the confusion.
With the car running I check the battery and the voltage is at 12 and dropping.
Based on an earlier answer I presumed if the regulator was at fault I would be seeing a higher than normal charging voltage at the battery(14+).
What I really don’t understand is where can I check to verify if the alternator is providing an output to the regulator and the regulator is then not working. There are three wires between the alternator and the voltage regulator. Blue wire (d+), black wire (df) and brown (d-).
Is is safe to run the car with the vr disconnected and check voltage output at one of the lines coming from the alternator to the voltage regulator? If so should I expect to see some higher than 12v at the blue or black wire positions.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 03-06-2021, 12:33 PM
I'm not expert at your car's specifics, but I would guess that 1 VR wire is the voltage in from alternator. 1 wire is the field wire that would tell the alternator to energize or not, once battery is fully charged. And 1 wire is a ground.
I believe there's multiple failure modes available. If the VR is not properly measuring voltage it could fail in 1 of 2 ways; either not provide current to battery and battery runs down, OR field wire doesn't alert alternate to stop charging and battery overcharges. Additionally, a failed alternator could also not provide current to battery which allows battery to run down, regardless of what the VR tries to do.
Not sure if car will run with VR disconnected, but my guess is that it won't. That's why I suggested taking alternator to a FLAPS to be bench tested. If alternator is bad, its the alternator. If alternator is good, its probably the VR.
If the battery is below 13.2 volts (most batteries have 6 2.2 volt cells in series) then alternator should be charging.
- 1979 RX7 enduro
