Seeking opinions on lift points for 944 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Seeking opinions on lift points for 944
Old 02-25-2021, 08:38 AM
Mark Hubley's Avatar
Mark Hubley
Default Seeking opinions on lift points for 944
Anyone here have opinions (preferably based on experience) about front lift points for a 944?
Online I have seen different views on whether it is safe to use the points behind the front wheels indicated by the red arrow (the pic shows drivers side):
I have a Nussbaum 9,000 lb two-post lift. The forward arms reach the lift points on the frame (yellow arrow in the pic), but with little room to spare. Hard to explain, but I need to have the forward arms extending straight toward the middle of the lift (perpendicular to long axis of the car) to get to the frame. This has the car positioned farther aft on the lift than I would like. Though I feel it is safe. I used to put my rear-engine 996 on the lift, so it can handle the center of gravity being a bit off.
That being said, if the lift points behind the wheels are safe to use, I would much prefer to use those points.
This pic is from the Pelican Parts web site, and they say both points are safe. However, I have seen others state that the points indicated by the red arrow should never be used. Sure looks like lifting is what they are intended for.
TurboPooch???
1986 944 Turbo
2017 VW GTI
2016 F-250
Formerly owned Porsche/BMW:
2006 325i
2000 911
1987 924S
1999 Boxster
1986 944
Old 02-25-2021, 10:40 AM
Building a Worm Hole.....
I recall reading somewhere that the RED points were used by the factory to move the chassis on the assembly line. I've used the YELLOW points on my 944s without any problem.
- 2000 Boxster S (the wife's)
- 1979 RX7 enduro
- 1986 944 (under new mgmt)
Old 02-25-2021, 10:59 AM
I have used the round ones for my lift all the time. I don't think I have created any problems.
Old 02-25-2021, 12:53 PM
racer's Avatar
racer racer is offline
racer
The round ones (red) could result in slight bend in the floorboard above. That said, I agree with others, both can be used but the yellows are better. Second reason folks likely use the red/round points is that their jack cups around them making it feel sturdier.
Dave
- 1970 914-6
- 1987 924S
- 2000 Boxster
- 1987 944
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 02-25-2021, 12:58 PM
John Clay's Avatar
John Clay
I always used the yellow, but I'm sure shops have used the red. Although it looks like TAG uses the yellow.
John Clay
2011 Cayman
1986 944 "Traffic Cone"
2013 Scion FR-S
Old 02-25-2021, 01:27 PM
Round is the Factory recommended lift point. Yellow frame rail works but interferes with access. Funny that in the above picture that the frame rail looks dented up.
Just don't use the pans.....
Old 02-25-2021, 01:52 PM
dnwong's Avatar
dnwong dnwong is offline
dnwong
I have always used the round (red) ones. In fact that is what I use to store the car when it is on the lift. But I am no expert.
Dudley
Aldie, VA
99 996 C4 Black/Black Areo
86 951 Graphite / Burgundy
2002 BMW 530i
2008 Volvo XC90
1995 Chev Astro (workhorse going-bald)
Old 02-25-2021, 03:09 PM
The boy's Avatar
The boy The boy is offline
The boy
ive had the red ones bend and kink the floor of my racecar. Also the dent that was on the bottom of one of the front fenders when we had it was most likely put there by using that point and not using a block of wood or adjusting the pads. We typically use the yellow
Robbie Wilson
87 944 (the red car)
86 944 #171 ITS/SP2 racecar
3 time 944 cup world champion
Old 02-27-2021, 11:27 AM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
Yep, always use the frame (yellow) in the front and will usually move back 2 or 3 more inches so the metal under trays on the turbos come off without hitting any of the arms. That area is boxed metal instead of flat metal and much more resistant to bending as mentioned. The flat spot on the bottom of the aluminium torsion tube ends make a nice spot for the rear.
Steve Potomac PCA Co-CI
89 944 Turbo Racecar, used to win a bunch of races
98 993 C2S w/Aerokit II
77 911S project
70 Boss 302
86 Mustang SVO
08 F250 SD Diesel
15 Audi SQ5
Old 03-01-2021, 03:18 PM
jerome951
I've jacked the front end of my car numerous times on the red donut without issue, but always support (for doing work underneath) w/ a jack stand under the frame rail (2x4 between the stand and rail).
Jerome Welte
'89 951 track car
'13 135i cab
'15 Ford Fusion plug-in hybrid (DD)
'06 Toyota Tundra
