My next project - The Green 911 gets a makeover - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » My next project - The Green 911 gets a makeover
Old 01-23-2021, 05:48 PM
rothaus's Avatar
rothaus rothaus is offline
rothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threadsrothaus has nine HoF threads
Default My next project - The Green 911 gets a makeover
I started my next project. The 71 911. My Autocross car for 10 years. But now it time resurrect it and built a nice outlaw 911. Started the disassembling. Here are some pictures to get started:
More to come.
Cheers
Engelbert
LED Lights for Classic Porsches
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1984 911 Targa, 3.6L
1982 911 SC
1978 1303 Kaefer Cabrio
1976 914
1971 911T - Current Project
Old 01-23-2021, 05:52 PM
Did you finish the 944?
Old 01-23-2021, 08:07 PM
Looking forward to this, really liked the green car in the first pic!
Old 01-24-2021, 09:02 AM
rothaus's Avatar
I need to finish the seat. There are a few things to be done, but I will do it in string when I register it to drive.
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
Old 01-24-2021, 07:55 PM
racer's Avatar
racer racer is offline
racer
What a filthy wretched starting point to make an outlaw from .. Cant wait to see the progress!
- 1970 914-6
- 1987 924S
- 2000 Boxster
- 1987 944
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 01-28-2021, 07:09 PM
rothaus's Avatar
Disassembling continues on the Froggy.
Removed the front wire harness and the fresh air system.
The dash pad had a cover, which I left back then, but this time it will be done right.
I just cleaned it up a bit before I'm putting it away.
The gauges are all out, and the wire harness from front is pulled inside.
The doors are all disassembled. Here the locks. I clean stuff up before packing it away. One before the other after cleaning.
The calipers removed.
Next the suspension.
Got more items already cleaned up a bit before put them in storage.
Most of interior parts are removed now.
The steering rack is ready to go in storage.
Almost all components removed. This car was disassembled a lot faster then those before, LOL.
To be continued.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
Old 01-28-2021, 07:24 PM
Why did you remove the wiring harness? Are you going to rewire or just replace after paint, etc is done?
IndexFingerRacing.com
2016 Toyota Highlander (wife's DD and my new tow vehicle
2009 911 C2S Coupe "The Green Car"
2006 Dodge Durango - sold to a Dorki
2003 Acura MDX - Just shy of 200K
86 Black 911 Coupe race car (owned 2010-2016)
86 Gold 911 Targa (owned 1998-2012)
82 WineRedMetallic 911 Targa (owned 1986-7)
Old 01-29-2021, 12:19 PM
Hunter's Avatar
Hunter Hunter is offline
Hunter
That seems like a lot of work because the car was dusty........
90' 964, Red, Number 692 (Misty)
Trailex (Dusty)
Old 02-04-2021, 09:49 AM
rothaus's Avatar
It need some repair. Maybe I just make a new one, not sure yet. Include some DRL, oil cooler fan, etc.
I started to delete the battery boxes, since the battery was relocated in to the smugglers box. This will also free up some space for additional oil cooler or so.
The nose panel need also some work. Back than when I butchered the car for Autocross, I just used some body filler to make it look OK.
I have a new lip piece coming, so this gets replaced, the rest under need is still solid, just a bit banged up.
I will fix this. Since I have the section for the air flow for the oil cooler, it made no sense to replace the complete nose panel. I would have to cut out that section again.
So I removed the brace plate behind the lock and will clean it up and bang straight and weld back in.
I got most of the top section straighten out. Just waiting for the lip piece to com in so I can cut out the old and replace it.
To be continued
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
Old 02-09-2021, 08:57 PM
hkspwrsche's Avatar
hkspwrsche hkspwrsche is offline
hkspwrsche
Looking good!
Harold
GrandPrix White 993
Irish Green 356C
