Brake pressure switch question - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Brake pressure switch question
Old 01-06-2019, 05:48 PM
Tito
86911TLCAB
Default Brake pressure switch question
1982 911 sc
Both My brake lights have recently stopped working. The brake light on the dash has also lighted up and won't go off. When I check for voltage I don't appear to have any voltage coming out of the switch ( have only tested the front most switch so far). Will the system work with one bad pressure switch or must both be operational for the system to work properly? Thanks.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-06-2019, 06:51 PM
Originally Posted by 86911TLCAB View Post
1982 911 sc
It should though Iíve had both switches go bad. One goes bad and you donít know it till the othe ones doesCheck the fuse if you havenít done that yet
Old 01-06-2019, 06:54 PM
Tito
86911TLCAB
I guess you don't know until the second one fails. Have checked the fuses and continuity. Ordered a couple of switches. I suppose everything has a shelf life. Thanks Dave.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-16-2019, 02:13 PM
Tito
86911TLCAB
changed both switches...system operating...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-16-2019, 02:19 PM
Those switches go bad all the time. I've gone through at least 4 sets. I wonder if track use and repeated high pressure cycles in the braking system has anything to do with it?
Old 01-16-2019, 02:27 PM
Tito
86911TLCAB
i saw a mod for adding in a mechanical switch...seems pretty easy to do...may add it in...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-16-2019, 04:12 PM
hoophead's Avatar
hoophead hoophead is offline
hoophead
I suspect it's running the entire brake light current through the switches and that is what is frying them. Even two in parallel can't take it. I've replaced several sets myself.
Jeff S
'09 Cayman S
'05.5 Audi S4 Quattro
'18 GMC Tow Beast
'04 Audi A4 Quattro (kid car)
'08 Audi A4 Quattro Cab (another kid car)
'08 Audi TT Quattro Coupe (yet another kid car)
'02 Audi TT Quattro Coupe (current project car)
ďI want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car.Ē
Old 01-17-2019, 07:25 AM
They work in tandem. If one fails the dash light should go on. In addition to the brake lights they are set up to light the dash when one brake fluid loop develops less pressure that the other. Clever design, Poor build of the pressure switch.
Old 01-20-2019, 04:08 PM
Tito
86911TLCAB
For the moment they are functional. Dash light has gone out. Brake lights working. Let's see how long the switches last.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
