TDC question - Dorkiphus.net
Old 01-04-2019, 05:10 PM
pookie's Avatar
pookie pookie is offline
pookie
Default TDC question
I am working on getting my car up to speed before spring. And I'm ready to do a valve adjustment (85 3.2). Admittedly it has been far to long since I have done a valve adjustment, but I don't remember the blue or white painted marks. I did take my car to a Porsche mechanic in Nashville to sort out an issue I was having after installing the 3.2, but that was a long time ago as well and I'm not sure if he is still alive. However, he could have put the marks there. I believe TDC is the white mark with a notch surrounded by two blue marks on each side, but when I look at the dist cap and rotor it looks like the notch on the distributor is slightly off to the cap? When I spin it around to the white w/blue dots again the rotor points to the other side of the distributor. The other pic is of the other notched location that just has a single white dot.
Thanks
1976 911 S Targa (I know, I know, mid year....but I LOVE HER) now a 3.2 scalded cat.
2008 Mustang GT convertible - DD
Old 01-04-2019, 05:25 PM
pookie's Avatar
pookie
http://forums.pelicanparts.com/porsc...-my-3-2-a.html
I found this which says I’m on the right mark, but what about the rotor being slightly off.
Old 01-04-2019, 06:28 PM
Also, recall that a four stroke motor rotates twice each cycle, once TDC compression (rotor fires spark plugs) and once TDC exhaust (rotor half way round) so your observation is correct.
Don't know about the dots, sorry.
Old 01-04-2019, 06:55 PM
Tito
86911TLCAB
Your good. The first picture where rotor is pointing up towards fan is tdc for 1. Set your valves. Then turn 120 degree (should be another notch) and set 6. On and on. HAs the car been running ok? Adjusting timing in 3.2 is major surgery. If car is running ok it is probably fine just off the mark.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-04-2019, 07:00 PM
pookie's Avatar
pookie
Thanks guys.
Itís been running fine, I just figured itís been so long since I adjusted the valves so I needed to check them.
Old 01-04-2019, 07:24 PM
Tito
86911TLCAB
It is a good thing to do. I have been setting them the traditional way then verifying with the backside method.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-04-2019, 10:00 PM
pookie's Avatar
pookie
Well....that sucks
And is this as bad as I think it is?
Old 01-05-2019, 07:53 AM
rothaus's Avatar
rothaus rothaus is offline
rothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threads
Originally Posted by pookie View Post
Well....that sucks
Oh boy, looks like a broken head stud. That's part of doing the valves, torque the head nuts, to confirm the studs are all OK.
It's a good thing you did the valves, and not keep driving like this.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1987 944 Hybrid Project
1986 944 The Beater
1982 911 SC
1978 1303 Kaefer Cabrio
1976 914
1971 911T - the Froggy
