Mini Project: My 82 SC Suspension Refresh - Page 3 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Mini Project: My 82 SC Suspension Refresh
Old 11-24-2018, 12:58 PM
rothaus's Avatar
rothaus rothaus is offline
rothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threadsrothaus has eight HoF threads
Looks like you removed the undercoating? If so what did you use. I’ve found running a torch over the rubbery mess fist helps get big chucks off quickly. The of course the final cleanup always sucks!!
Fortunately There was no black undercoating, it was just dirt. I was able to clean it with oil eater, mixed with water (50/50), and a brush. Wipe off the rest with rags. I like the Ikea dish brushes $0.99 each.
The black undercoat removal worked for best with kerosine. Use it in a spay bottle, spray on, let soak in, and I used the same dish brush to brush off, spray again, repeat, until its all gone. I put always a plastic on the floor, and sprinkle some oil dry to soak up the Mess.
Here is a picture when I did it on the 70 991T
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1987 944 Hybrid Project
1986 944 The Beater
1982 911 SC
1978 1303 Kaefer Cabrio
1976 914
1971 911T - the Froggy
Old 11-25-2018, 10:13 AM
Scuba's Avatar
Scuba Scuba is offline
This space for rent
Scuba
Curious - do you do electrolytic rust removal or just media blast?
Scuba Steve
“Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba....” (cars, too...)
'83 911SC track car, MI State Police Blue
'05 Carrera S, Black
'09 BMW M3 Coupe, Interlagos Blue
'13 KTM 350 XCF-W - Trail demon
'12 GasGas 280 TXT Econo - Trials hell-spawn
'03 Kawasaki ZX-636, CCS#437 (former life)
'89 Yamaha FZR-400, WERA#501 (former life)
'94 Kawasaki ZX-6E, WERA#501 (gateway drug)
Old 11-26-2018, 11:56 AM
rothaus's Avatar
I just media blast the parts. Some time I use muriatic acid for small pieces, like bolts and nuts.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
Old 11-27-2018, 09:38 AM
Tito
86911TLCAB
so on the picture with the front shock mount where there is all that black stuff, is that put on there at the factory? reason i ask is mine is also all black and would then make me think the rubber could be original?
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 11-27-2018, 11:14 AM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
This is exactly the direction I thought/hoped this thread would take. Love watching you take shit apart, clean it up, then reassemble.
Rob T.
2006 Carrera S
1995 BMW 325is (Spec3)
2012 GMC Yukon XL Denali
Old 11-29-2018, 11:05 AM
rothaus's Avatar
The black stuff is more like paint, not undercoat. So I just left it alone.
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
Old 11-29-2018, 11:10 AM
rothaus's Avatar
Made some progress:
Drilled out the broken stud and installed a helicoil.
The engine harness is ready to go.
Cleaned, blasted, and powder coated some parts.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
Old 12-02-2018, 12:28 PM
rothaus's Avatar
Heater flaps are assembled and ready to go back in.
Rear suspension is ready to go back in.
T-bars and spring plates adjusted and installed.
A little bit picture fun.
Brake pieces going back on.
Parking brake installed.
I ended up removing the Oil tank, so I could get better access to clean up under the right side rear fender.
Here after cleaning. I also noticed the the rubber gromments for the tail light wire is hanging out, so I need to remove the tail light housings and fix that.
The Oil tank need also some cleaning and reconditioning.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
Old 12-02-2018, 01:24 PM
Mini Project: You keep using those words. I do not think they mean what you think they mean.
https://www.youtube.com/watch?featur...&v=G2y8Sx4B2Sk
Old 12-07-2018, 08:20 AM
rothaus's Avatar
So I got the calipers and valve covers coated Indisch Rot.
I know, I know, it's original that way, but I like it that way. LOL
Adjusted the valve clearance, and installed the valve covers with new silicon gaskets.
Installing the cooling shroud.
It starting to look like something.
Happy Weekend
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
