1985 911 - Crank, but no start.... - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 1985 911 - Crank, but no start....
Old 08-30-2018, 10:58 PM
Late to the game (I've been off Dorkiphus for a month, 130 threads to catch up on).
Had similar but not identical problems after a rebuild on my '86. Would start about half the time by cranking it, but would start 100% of the time roll-starting it. Replaced many parts and it spent months in shops. Finally took it to Matt de Maria (Stuttgart Performance Engineering) at the insistence of Old T (remember him?). Matt heard the story and knew what the problem was, had it fixed in <2 hours (and made a customer for life). The flywheel sensor gap was 2.4 mm instead of the spec 0.8 mm.
To get to the flywheel sensors with engine in, jack up the rear or driver's side of the car, remove the rear wheel, and you can remove/replace/adjust/loosen the flywheel sensors with a ball-head Allen wrench. It can also be done with a straight Allen wrench, 1/6 turn at a time... If replacing, use silicone on the firewall gasket to get it back in place. I replaced both flywheel sensors at VIR one evening - with a straight Allen wrench so it can be done.
IndexFingerRacing.com
Vicegrip: "The best way to buy speed in bikes is purchase less food. "
2004 Toyota Prius - Back-up DD
Old 08-31-2018, 08:42 PM
Swoboda Swoboda is offline
Swoboda
Actually, great timing. I plan to tackle the sensors this weekend.
Thank you for the note about the gap. Hopefully, that won't be the case, but at least I now know to check it.
1985 Carrera Targa
Old 08-31-2018, 11:34 PM
Does the car roll-start easily? Might just be the gap. Or could be the sensors (which are not particularly expensive).
Old 09-01-2018, 08:27 PM
Swoboda
Well, I tried to replace the sensors. No luck.
They're the original wires and 33 years has them pretty well stuck.
The screws came out, and I can get them to spin a little, but there is no way to pull them out. I tried to wiggle and pull, but no luck.
I'll have to get a tow to a shop.
Any suggestions for a shop? In addition to the sensors, I'd like a simple check-up to know what may need attention.
I'm in Towson. Ralph's and SSI on Joppa Road have been suggested. Any thoughts on either of them?
Thanks for any advice!
1985 Carrera Targa
Old 12-02-2018, 09:23 PM
Swoboda
Just to close the loop on this thread, the problem was the failure of the old speed and reference sensors.
The shop replaced them with an identical set of BMW sensors that I sourced that cost much less than the Porsche version, and it started right up!
Thanks for all the help!
1985 Carrera Targa
Old 12-03-2018, 09:42 AM
Tito
86911TLCAB
could you post the actual sensors you purchased...just so when i have to do this, i don't have to research the right ones...thanks...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 12-05-2018, 08:36 AM
Swoboda
Originally Posted by 86911TLCAB View Post
could you post the actual sensors you purchased....
This is the link to FCP Euro. I found they have good prices and quick service.
https://www.fcpeuro.com/products/bmw...sch-0261210002
The BMW part number is 0261210002 and the part that I used was made by Bosch.
100% plug-and-play and half the price.
Cheers,
LS
1985 Carrera Targa
Old 12-05-2018, 09:15 AM
Tito
86911TLCAB
Thanks.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
