1985 911 - Crank, but no start.... - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 1985 911 - Crank, but no start....
Old 07-17-2018, 07:57 PM
Swoboda Swoboda is offline
Swoboda
Default 1985 911 - Crank, but no start....
Hello: I have a 1985 911 that was running great, then just stopped working.
Quick story: The car was running fine. I recently drove it to work, came home, and parked it in the garage. When I went to start it up a couple days later, it just cranked.
It doesn't start and it doesn't "catch" or "stumble".
I switched the DME relay with a new one. No change.
I switched the ECU with a known good one. No change.
I jumped the fuel pump at the fuse box and it runs.
I still have to check for spark--I'm running solo so I can't turn the key and be at the engine to check (but I will get some help soon).
Any thoughts on what it could be?
What I last had it out it was on one of those blazing hot days a couple weeks ago.
Thanks very much for any thoughts!
1985 Carrera Targa
Old 07-17-2018, 08:46 PM
No start problems are usually flywheel sensors or DME relay. Try jumping the fuel pump so that you hear it running, then try to start. The fuel is a closed loop system so it’s fine to jump it for the tests.
If it starts and runs well, you probably have DME relay problem. If it tries to run but does so badly probably the flywheel sensors.
Old 07-17-2018, 09:16 PM
Swoboda
Thank you! I'll give that a shot.
1985 Carrera Targa
Old 08-18-2018, 01:58 PM
Swoboda
I tried jumping the fuel pump, and could hear it running. I tried starting the car, but still no start or even a “catch”.
I tried cranking for a good bit several times to ensure that the gas made it to the engine and I gave it a chance fire up.
Does this indicate the sensors?
Can I get access to the sensors with minimal jacking? The car’s in the garage with little space to maneuver?
Thanks for the advice!
1985 Carrera Targa
Old 08-18-2018, 03:18 PM
I always see the sensors tagged as a source of failure, but how often do they just fail? Did you swap in another DME relay?
1983 911 SC Targa - 1990 944 S2 - Past: 1986 944 n/a - "Doublemint"
"Every one drives to DE but few fly to flight school." - Vicegrip
"Sometimes arguing/reasoning w/Steve is like looking at a compass while having a 2lb magnet in your pocket." - }{arlequin
Old 08-18-2018, 06:05 PM
Richard Curtis's Avatar
Richard Curtis
old coils have been known to generate a weak spark over time, too weak to ignite the fuel mixture. Spark color should be blue. If any shade of yellow, orange or red, replace the coil.
Richard Curtis
Old 08-18-2018, 09:06 PM
Tito
86911TLCAB
If you can get under the rear of the car you can get to the flywheel sensor.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 08-19-2018, 08:06 AM
Swoboda
I did swap the DME relay with a new one and, when that didn't work, I also swapped in a known good ECU.
I may have a spare coil to try.
I've have the car for 10 years and have been doing regular maintenance to it, but I've never looked at the sensors.
I'll see if I can play around with it more today.
I appreciate the suggestions and help!
1985 Carrera Targa
Old 08-19-2018, 08:11 PM
Len 911's Avatar
Len 911 Len 911 is offline
Len 911
I have an 85 also...had the same problem and it was the sensors on the flywheel..wasn't to bad of a job...I used the BMW sensors way cheaper and are the same..
Good luck
Old 08-20-2018, 09:30 AM
Tito
86911TLCAB
I recently swapped out the camshaft sensor in my e36...I decided to strip the wire to see what it looked like inside...and basically the covering on the individual wires was crumbling and wires were shorted in spots...so these things live in a hot environment and like anything else can eventually cease to function...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
