#91
I have a large crimper if you'd like to borrow it. Designed specifically for the large gauge wires and is hydraulic. The hammer type has less opportunity to see and adjust, I think.
https://www.amazon.com/TMS-Hydraulic...ble+crimp+tool
#92
I've used copper compression terminals in the past. Better than lead and have held up nicely.
Similar to this:
#93
Those look nice! All my connectors were Panduit Ring-style connectors and not actually battery terminal connectors.
#94
Thank you both
I somehow missed the low end of the crimper options and only saw the $$ stuff. I need to look into this further, as usual there are more opinions than people on the proper terminal connection method.
#95
I have one of these... used it a couple times, and it works well enough. I like the compression terminals that Charlie posted better.
#96
this one
#97
I like this one. Though pricy unless you change a lot of pads........ lol as if $1000+ tyres per weekend is ok!,
Can use a workout 6 pot pad for larger calipers
#98
Router bits
Is there a combo rabbet set worth getting? I dont feel like spending $50/ea for 4-5 bits I might use another 10x but also dont want to buy junk. toolstoday.com sells this for ~$50. So many options out there, are they really different or just different color boxes?
#99
I stick with Whiteside, Freud or CMT bits typically in that order. Always had good results with those. Whiteside sells the same kit on Amazon for $55: https://www.amazon.com/Whiteside-Rou.../dp/B000K2C87G. That's what I'd buy personally.
#100
Excellent, thank you.
Glad I checked, I have a 1/4" shank router. Need to decide if I should get the 1/4 set or a new router. Thanks again Jazz
