Cleaning really small connections?
My E46 has developed a case of the codes... After checking lots of stuff, the issue is coming from either bad harness or this bad connection at the DME. It looks like a green corrosion issue probly from road salt mist getting up there somehow. (pic)
It will run fine until I put the DME cover on the it gets wacky. How would you go about cleaning these terminals/connector?
Tim 05 Cayenne TT 03 M3 (sold) 82 911 SC (sold missed) 90 C2 (sold missed) 87 928 S4 (sold) 85.5 9 fofo (sold ) |
Car's toast. I'll give you $2K for it.
What? no love for the Bavarian brotha?
I used some very fine sandpaper with a small screwdriver for pressure on the pins. On the connector I used a acet torch tip cleaner and followed up with MAF cleaner and compressed air. Just ran it for 5 minutes without any codes....we'll see. This thing is like a HP brother to the fofo with its nitpicky issues.
maybe an ultrasonic cleaner with some non-aqueous solvent?
Took the car to my local shop that has BMW diagnostics this morning, looks like my connector cleaning did the job as it has no codes and all components checked out. I have read on lots of the BMW forums of cars with this same type of issue(s) none mentioned what I found......
I cleaned a receptical like that on my 1987 Merkur XR4Ti by dunking it into a mixture of a ~ one tbl spoon of baking soda in a cup of water. A few minutes was all it took to get rid of most of that green corrosion. Also works to clean corrosion off battery terminals. I does have a tendancy to fizz up and could potentially spatter though....
Rich F. 2017 BMW M240 xDrive Vert 2004 BMW 330Ci Coupe (DD) 1996 BMW 328i 2006 Cayenne S 1980 SC Targa (A1R KULD) Gone but not forgotten: 2010 Boxster S (sold) 2000 Boxster S (sold) 73 911T Targa (sold) 67 912 (sold) |
What would be a good non conductive paste or? for this connection? I have some spark plug stuff, would that work?
CRC makes a electrical contact cleaner...
Then I would just probably use some dielectric grease.
Wonger EX-#121 IP/GTS3 BMW E36 M3 HERE-#121 GTS3/4 BMW E46 M3 http://www.Salazar-Racing.com http://www.brakeswap.com PM me parts/brake requests and orders. I will donate a portion of order to DorkiBoard! |
Thanks Eric, Exactly what I was looking for.
And thanks for the parts as well as putting up with the nOOb questions.
