Saving another one, this time a 1984 Carrera Targa - Page 8 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Saving another one, this time a 1984 Carrera Targa
Old 03-22-2020, 02:11 PM
catron1's Avatar
catron1 catron1 is offline
catron1
Unbelievable work, sad that I won't see you at Hershey this year...
1980 911sc
2019 Ford Raptor
1987 Mercedes 560sl
2011 BMW M3
1986.5 928s
1987 944 16v
1973 911t
1969 911t "My first car"!!
1969 Westfalia Bus
1973 Volks Superbeetle
Old 04-11-2020, 10:06 AM
rothaus's Avatar
rothaus rothaus is offline
Time for an update:
Made new door panels. I used expanded PVC for the cards. I had an upholsterer make the stitching for my according to my layout.
I added black venting all around. and used the same pins also at the bottom, so there are no screws.
Next thing was to assemble the 993 mirrors. I hade to make a tool to compress the springs with pulls the mirror and base together. The flag mirrors got a hollow bolt, which can be screwed in or out. These push in and twist, which is impossible just by hand.
The next thing is the wiring for these mirrors. They are different from the flag mirrors. I had to add a relay in each mirror to make them work.
At least there is enough place for the relay.
Now that all is working, including the power locks, power windows and mirrors, I can install the door panels.
I made some door panel seals from thick plastic sheet.
I did not install the turning locking knob and no speakers in the doors. I wanted look nice and clean.
I also made some new pins for the door locks, so I can manual open them in case needed.
Cheers and happy Easter
Engelbert
2012 Boxster S
2006 Cayenne S
1984 911 Targa, 3.4L
1982 911 SC
1978 1303 Kaefer Cabrio
1971 911 3.6
1966 912 - Future Project
Old 04-11-2020, 11:40 AM
OMG that is fantastic! Engelbert, you set the bar awfully high!!
1999 Miata ("SM") race car
Old 04-20-2020, 06:02 PM
rothaus's Avatar
Haha, I'm not setting the Bar, I am the bar. LOL, just joking
Anyway, here is a little update what I did since last post.
I decided to make a rear seat delete shelf, since nobody will ever sit there. This way I got a good place for the speakers. I didn't want to cut holes in the new door panels, and I didn't want any speakers in the rear self.
Test fitting before finalizing.
I made a little edge at the front, so things don't slip forward. The holes are for the speakers.
The next on the list was the shifter.
A piece of aluminum round bar
Machine it.
Some wood
Stack it, glue it.
Test fit it.
I also finally installed the instrument gauges and the steering wheel.
I will use a different wheel later, this is it for now. I'm looking for a 370mm wheel.
That's all for now.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 04-20-2020, 06:09 PM
DonNewton's Avatar
DonNewton DonNewton is offline
DonNewton
Jeez, just stop it. I have never seen such craftsmanship (from one man). I think I'll take my cars out to the cul-de-sac and set them on fire. . .
Old 04-23-2020, 08:55 AM
rothaus's Avatar
Here is a little preview what the front bumper will look like. Almost done.
I made some custom LED DRL/Turn signals. The parking lights will be implemented in the headlights.
Here with the grills installed.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 04-23-2020, 09:15 AM
onboost's Avatar
onboost onboost is offline
onboost
Elnglbert mein Freund du bist auf einer Rolle!
Ich werde Ihnen später eine PM senden.
RGruppe #180
PCA Potomac + 35yrs
Old 05-22-2020, 09:43 AM
rothaus's Avatar
I finished the speaker install in the rear seat delete shelf. I used Infinity reference speakers. The speakers don't come with grilles, and I could not fine any grills, so I made some with the 3D printer.
Here are some pictures.
Next is the transmission. Will post soon about the disassembly, etc.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 05-22-2020, 11:25 AM
Nerfbar's Avatar
Nerfbar Nerfbar is offline
Nerfbar
Looks like a job for a Bridgeport milling machine.
Barry
18 Carrera cab
15 Macan S
Old 05-28-2020, 07:10 PM
rothaus's Avatar
I started with the transmission. It came out of a 78 911SC, and I had it sitting for the last 8 years or so.
First I cleaned it up a bit from outside. This was good enough to start with disassembling.
Here are some pictures as it comes apart.
I clean up the pieces as I go.
Got the casing cleaned up
And here the 2 shafts out.
R/P looks good.
Got it all disassembled for inspection.
Next: check all parts for wear and make the list. I decided to replace all bearings, and I know for sure the first gear synchro ring must be bad.
More to come.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
