#91
Time for a quick update.
Fitted the oil cooler. I found a 964 cooler. Since this one is wider, I had to made some ducting, so the air will be forced through the cooler. I also added a fan. Headlights installed. The Targa looks happy. I made some all black custom headlights. Finally on the wheels. Started to get the engine ready. I will remove all the pieces around the engine and clean up a bit. I also will use the 993 crossover heat pipe, since I got the 993 heat exchangers. Here I got it cleaned up a bit. Got some high temperature flex hose. I made some custom pieces for to connect the hose to the duct. I had to do some repair of the engine tin pieces. Here are some pieces finished. Cheers Engelbert
#92
I also finished the DRL and turning signal. Here some pictures and video.
DRL Front Rear Cheers Engelbert
#93
Hah! 'clean up a bit' ....
#94
OK, looks like it's time for a little update:
I grit blasted the cooling fan. It didn't looked that bad, but had a few little bubbles in the paint. And after blasting it I found that it is a bit rough. There was a lot of filler on that thing from the factory. So I used some magic JB weld to get it smooth again. And powder coated it in guards red It's amazing what JB weld and PC can do. I did the Valve covers as well, as some other small pieces. I had always a tiny leak from the left timing chain cover. It was not much, but that drop which was hanging there after a while was annoying. So I replaced the seal with a new one. Next: Rebuild the fuel lines. I reused the metal lines and fittings, and used new hoses which are OK for Ethanol and new ferrules. Finishing up the heating duct system. How do they say ? The devil is in the details. I didn't like the look of the belt pulley, so I made a hub to go over it for a cleaner look. I started to install the DME wire harness, and hope soon we can hear some noise coming from the engine. Cheers Engelbert
#95
Engelbert,
What do you use to crimp the metal on the fuel lines? Looks so professional (heh heh - as opposed to everything else you do...). The fan is a work of art!
#96
Literally wondering the exact same thing. Those lines look great.
#97
Interested to see as well. I suspect it is similar to one that wandered into my shop a while ago The crimp patterns look quite similar. The little hand powered setups can work well in low volume production. Fitting and crimp die match-up is key but it can save $ and produce better results in the long run. The example is one for AC lines but you can get dies for all kinds of stuff.
https://www.amazon.com/iGeelee-Hydra...a-752210713618
#98
The one from amazon is basically what I use for AC lines, but it doesn't work for fuel lines. I got a hand powered one, as you describe, for 5 different sizes. It works actually pretty good, I was surprised. Cheers Engelbert
#99
Yep. I grew lazy having a big Weatherhead ton unit at work that can make everything from air lines to 5 ply lines for the forklifts. Had to replicate on the cheap.
#100
I made some progress.
Engine ready for installation. Here it is in. Installing the oil lines. Made a license plate holder with integrated LED lights. Also made cut-outs for the exhaust pipes. I made a heat shield above the muffler. Here the finished set up for the exhaust. Blasted and ready for some coating. Coated. Now it need to sit, or hang for a few days before use. After sorting out a few electrical issues the engine started up, no muffler. This car did not had an engine for a long time. Still a lot more work to be done. Cheers Engelbert
