Craigslist unisaw find. - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » Craigslist unisaw find.
Old 01-02-2022, 05:31 PM
Yep the 52 unifence. My contractor had the 32. I mothballed the contractor and stole the fence for this setup. Replaced the bearings with some good deep groove bearings. Took the machine apart, cleaned and lubricated what needed it, reworked and air sealed the case for dust collection. This required making a box to cover the motor and adding a 4 inch duct at the bottom of the case. Put things back together with a new set of belts. Sanded and painted the case and built the table while the paint was drying. 48”X96” working deck with a router plate built into the far end. Lots of working space for cutting flat stock and FSA for assembling things. The holes in the sides are for clamps. Will add some dovetails for deck clamps later. Have a roll around table that will be set to the same hight as the saw deck so it can be used as an out feed table when needed. Tuned everything to OCD levels of true and square. The contractor saw was tuned and cut well enough for all but the most precise small work. This saw cuts as well and a bit better in thick stock as the RPMs are more stable.
The saw and router share the fence guide and there is also a high precision incremental fence for small accurate stuff like triple and micro dovetails.
The original wiring had the control power transformer on when the unit was plugged in. Power pig and you could hear it throughout the shop. I added a slap switch that cuts power to the transformer so it is a emergency switch and a shutoff at the same time.
Up next is a 4X8 router gantry for slab flatting and more. Starting to finally fill up the shop.
For some reason my small auxiliary dog Beans now likes to sleep in the bottom 1/2 of a 55 gallon bucket. He hangs out in the shop whenever I am there and often flops over wherever after chewing up any wood scraps he finds. Now he jumps in the barrel and zonks out.
Old 01-03-2022, 12:31 AM
Nice setup, the saw looks brand new
Outfeed table ... the luxury of space
Old 01-03-2022, 10:45 AM
Rob in VA's Avatar
Professional coach
Rob in VA
As I was reading your post, I was hoping you'd include a picture of the pup. Otherwise it would be criminal.
BMW Spec E46 #609
BMW specE30 #609
2004 911 GT3 - Seal Grey
Old 01-03-2022, 11:10 AM
Two of the three pictured. Buck the English black lab photobombed one. He is a big solid handsome fella that recently came to live with us.
Cmartin, oh to be sure I know the joy of space in a wood shop. My original was 1/4 this and I had to store this to use that. I still have some space even with the 115”X 60 router gantry table. What to find next? Still looking for a rebuildable 6 or 8 inch jointer. A spiral head 20 inch planer would not hurt ether. Might have to move into the other section of the shop.
Old 01-03-2022, 01:22 PM
Beautiful rehab, Kurt! And as usual well documented. Lovely shop puppies.
FWIW, I have a spare Jet 6 inch jointer at my MIL's in Oakton. Its yours if you want to make the drive in. Last time I used it 10 years ago it ran great. I bought it when my Makita combo planer/jointer needed the feed rollers redone. Probably needs surface rust and general cleaning. She is close to 123 and 66. PM for details if you are interested.
Old 01-03-2022, 02:51 PM
A 6 inch Jet would be great! Jet makes good stuff and you can get parts and aftermarket for them. Would love to take you up on it but I cannot take it for free.
I still go into Tyson’s 3 times a month.
Old 01-03-2022, 04:30 PM
We can work something out. My mother in law bugged me about it and the grandboys don't have room for it unfortunately. PM or email me at john(dot)bailey(at sign)rennlist.net
Old 01-05-2022, 09:14 AM
onboost's Avatar
onboost onboost is offline
onboost
Kurt's got all the fun tolls and machinery... !hat shall we build next?!
RGruppe #180
PCA Potomac + 35yrs
Old 01-06-2022, 09:02 AM
Email and pm sent.
