Porsche & BMW Cars For Sale/Wanted Post For Sale or WTB adds for Porsche & BMW cars here. Strictly moderated. |
1978 No Sunroof/no Ac/manual/row Sc
1978 SC ROW No sunroof coupe. Manual windows, no A/C. Brown exterior. Stripped interior.
Good base for street/track car. Recently overhauld suspension, brakes, oil cooling. Some recent history Since Spring of '06 Timing and mixture set by ASG Alignment/Corner balance/Hight adjustment Valve adjustment New Carrera front cooler New Oil Lines New Fuel pump New Fuel Filter New Plugs New cap New Rotor New Wires Cleaned injectors Spring of '06 New shocks and struts all around - Bilstein Sports New front torsion bars - 23 mm New front Weltmeister bushings New front bearings Rack Spacers New tie rods New ball joints Rebuilt front calipers New front rotors New front pads (PF 97s) New rear torsion bars - 30 mm New Weltmeister adjustable spring plates New Weltmeister rear t-bar bushings Rebuilt rear calipers New pads (PF 97s) 3.31.00 - installed new brake master cylinder and starter. - fill with ATE blue dot 4 brake fluid 12.21.00 - heat exchangers replaced - new oil pressure switch installed - new oil return lines installed - clutch replaced - one piston and cylinder replaced - removed all 24 head studs, installed all new dilivar studs - installed all new heat controls, installed new cables, housings. 1.7.02 - installed new front strut inserts 4.29.02 - cap and rotor replaced - spark plugs replaced - all 4 brake rotors/calipers/pads replaced - turbo tie rods installed - ball joints replaced - front and rear hood shocks replaced - brake fluid replaced - transmission fluid replaced with swepco - valves adjusted An Autopower roll bar will come with a car. Current issues. -Small oil leak out of the oil pressure sender next to the breather. Have the new sender and gasket. -Second gear takes a slight effort to get into, but should go away with a new set of motor/trann mounts. $ 6,900 OBO Here are some pics from early spring, and a couple of the car on the track this summer... CLEANED UP MOST RECENT AS OF SEPTEMBER 25TH. Last edited by Eli; 10-13-2007 at 12:21 AM. |
Are those H4s?
Rich F. 2017 BMW M240 xDrive Vert 2004 BMW 330Ci Coupe (DD) 1996 BMW 328i 2006 Cayenne S 1980 SC Targa (A1R KULD) Gone but not forgotten: 2010 Boxster S (sold) 2000 Boxster S (sold) 73 911T Targa (sold) 67 912 (sold) |
Yes, H4s
Scott '10 Cayman S Last edited by kaefer; 05-21-2013 at 06:04 PM. |
Scott,
I'm tied up on conference calls for a better part of early morning. Will give you a ring around 10ish... |
Hmm...
I was doing some searching around and came across this thread that Eli posted about some rust issues: http://www.dorkiphus.com/porsche/showthread.php?t=4845 Is this the same car that's for sale?
Scott '10 Cayman S |
H4s, 6s and 7s x 16" Fuchs, full galvanized body, lightest regular SC made, big port 3 liter engine, no emission tests, 2”s more head room for helmets, how could you go wrong? I’m even tempted!
Scott '10 Cayman S Last edited by kaefer; 05-21-2013 at 06:05 PM. |
Scott,
The rust was repaired last December shortly after discovering the damage. All the rust was removed, the complete rocker panel got covered with POR-15, a new patch got welded in place, covered once again with POR-15, then RestoGRIP body filler, then tie-coat primer. |
