#21
Steve 996 GT3 996 C2 (gone) 911SC (gone) |
#22
I guess I need to update this thread.
First the QJ issue. The problem was that the fluid had remained in the short hose on one side and I just could not connect it to the long hose. I ended up loosening the connection to let some fluid out before connecting the hoses. After getting the car off the jack, there was a noise on the passenger rear strut every time we hit a seem on the asphalt during the test drive. Long story short, the car is at Dawe's and Peter has spoken to Tarett who is sending new rear camber plates which I suspect are what Ohlin has modified to fit the R&T struts. The should work better with centering the springs. In the meantime, GT3 master cylinder and booster, and underdrive pully are installed, and motorsport AOS is pending. The car should be ready for the first DE if the driver gets in.
Nader There are 3 sides to every story. Mine, yours, and the truth. 91 944 S2 - Mine, Sold 7? 914-6 Vintage racer - Mine 93 964 - Not mine 95 993 - Hers - Sold and will be missed 04 GT3 - ours? Doing double duties at DE, anyway 06 987 - Hers - plan to let son use for DE - My DIY A few others |
