Top dead center for leak down test - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > BMW Technical Discussions » Top dead center for leak down test
Old 12-09-2018, 07:26 PM
Tito
86911TLCAB
Default Top dead center for leak down test
Want to do leak downs on my 6 cyl e36. Does it matter if the cylinder is at the tdc during compression stroke or exhaust stroke?
Thanks.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 12-09-2018, 08:39 PM
William Miller's Avatar
William Miller
Thanks.
my guess is compression as tat is what i have always done. Want to make sure both valves are closed.
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 12-09-2018, 10:27 PM
Tito
86911TLCAB
I guess that is my question. Aren't the valves for a particular cylinder also closed at tdc for the exhaust stroke? Hence the leak down value would be the same? I guess I can try it and find out..thanks Bill.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 12-09-2018, 10:42 PM
William Miller
Google "valve overlap"
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 12-10-2018, 10:14 AM
Tito
86911TLCAB
thanks Bill...i will do that...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 12-10-2018, 10:19 AM
Valves closed, piston at the top. Find wherever that occurs and you are good If you are going through the effort, measure the piston travel with a dowel/whatever and watch the valves.
Old 12-10-2018, 10:33 AM
Tito
86911TLCAB
in the 911 i can easily tell that i am at TDC during the compression stroke because i can see the rotor as it goes around...i haven't done leakdowns on the BMW, but other than putting a straw or a dowel into the spark plug hole and waiting till it is out as far as it will go, i don't know how to tell if it is in the compression or exhaust stroke without removing valve cover gasket...i don't think the notch on the case is visible...but it would make sense to me as these are interference engines that the valves must be closed at the top position on both strokes...will give it a whack and see what i find...thanks guys...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 12-10-2018, 10:51 AM
Dandelion's Avatar
Dandelion
Unless Porsche BMW is doing something really weird, both valves will be open (slightly) at TDC during the transition from exhaust to intake stroke. This is the valve overlap referred to earlier.
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 12-10-2018, 03:14 PM
Tito
86911TLCAB
ok...so looks like i need to do this during the compression stroke...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 12-10-2018, 03:39 PM
Absolutely. Must be on the compression stroke.
