Saving another one, this time a 1984 Carrera Targa - Page 5 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Saving another one, this time a 1984 Carrera Targa
Old 01-09-2020, 10:39 AM
Looking good.
Please ditch the aluminum fuses for proper copper ones. Aluminum fuses placed in brass sockets should be illegal....
Old 01-09-2020, 12:08 PM
DonNewton's Avatar
DonNewton DonNewton is offline
DonNewton
A perfectly viable alternative:
https://www.pelicanparts.com/More_In...hoCNkUQAvD_BwE
Old 01-09-2020, 01:28 PM
Yikes, it's a shame JWest doesn't do a 911 version of his 914 panel like that.
His 914 kit for $155 sure is a lot less than that company's $360 911 unit.
'73 914 2.0 (2.7/6 conversion in progress)
'02 S6 Avant
'99.5 A4 2.8QT
'65 Falcon 80
Old 01-09-2020, 01:31 PM
Male an adapter that goes in the old torpedo slot and holds a modern spade fuse. That way you don't have to replace the existing setup and can convert any car.
Old 01-09-2020, 01:41 PM
hberwald hberwald is offline
hberwald
Perfect project for a 3-D printer! other than having to run that pesky wiring in the adaptor.
Old 01-10-2020, 07:47 PM
rothaus's Avatar
rothaus rothaus is offline
I need to know more about that Adapter !
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1984 911 Targa - Current Project
1982 911 SC
1978 1303 Kaefer Cabrio
1976 914
1971 911T - the Froggy
Old 01-10-2020, 10:05 PM
Cheers
Engelbert
Give me a couple weeks. Might be worth some effort
Old 01-11-2020, 02:13 PM
Handlebar's Avatar
Handlebar Handlebar is offline
Handlebar
This one (designed for 24v) appears to be one of the easier designs- I know the Dorki brain trust can improve on it.
https://www.thingiverse.com/thing:3448701/files
1988 911 Carrera 3.2
(1995 911 - gone)
1997 Spec Boxster - #121
2008 Subaru Outback
2008 VW Touareg 2
2010 Subaru Outback
Old 01-14-2020, 12:34 PM
que syrah syrah que syrah syrah is offline
que syrah syrah
Default Restoration
When I die, if I come back as a beat up old Porsche badly in need of life saving will you restore me please?
Damn impressive, well done.
Old 02-02-2020, 02:44 PM
rothaus's Avatar
Got a few things done on the Targa:
Heater flaps restored:
Before:
After: I know they should be redish, but who cares.
Cleaned up the oil tank, checked the lever sender, re-installed with new gasket. Installed the oil tank.
The pedal system was complete destroyed.
I found usable a replacement.
So I disassembled it.
Blasted.
Powder coated
And assembled it with new brass bushings.
Checked out the windshield wiper system.
Disassembled it and cleaned it up a bit.
Powder coated the frame and it's assembled, tested and ready to be installed
The parking brake lever needed also some attention.
So I disassembled it, powder coated the parts, assembled and ready for installation. Made a new release button from Aluminum.
Still sorting out and testing all wires.
Fixing some connectors.
Finally I mounted a large TV in the garage, so I can see things in the big picture.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
