Tools Needed/For Loan If you need to borrow some tools, or have tools to loan, post here. |
#21
Thanks, the front and rear strut nuts are different sizes (19mm & 21mm respectively). Drop me a PM with your contact info and I'll reach out to you if I go the angle grinder route.
- Chris 05' Carrera S -
#22
Arlington is near me. Bring sockets marked up with where you want them cut and we can knock it out in a couple of min. bringting the car is even better as we can figure out just what is needed and only cut as much as is needed to work.
#23
PM sent... will definitely take you up on your offer.
#24
Rear install went smoothly, fronts will be completed next week after I get a tie rod end separator tool.
Leaking rear shock (59k miles) New shock and springs installed Custom sockets compliments of ViseGrip! Thanks for hooking this up, they worked flawlessly and made the job much easier.
