Registration for VIR in Sept 4-6 open - Page 24 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » Registration for VIR in Sept 4-6 open
Old 09-08-2009, 09:54 PM
FTS's Avatar
FTS FTS is offline
Learning to Drive Again
FTS
I've gotten small amounts from the data but need to learn more about how to use it. But the immediate improvement came from the shift lights. I no longer watch the tach, and almost never hit the rev limiter now.
Which data logger are you using? If Racepak, maybe we can exchange some files for comparison.
Cheers,
Fatih
Old 09-08-2009, 10:24 PM
I'm using a G2X that I got from OG racing - very good deal because I maintain a blog linked to them (big discount, and even bigger for the G2X, one-time deal). For some reason, my software often doesn't recognize the track maps I got from Tom T, and I have to build my own (which might not map to those of other Dorkis). Is there a way, when you open a data file, to search for a track map when the only choice is "---NEW---"?
1999 Miata ("SM") race car
Old 09-08-2009, 10:40 PM
FTS's Avatar
FTS FTS is offline
FTS
Great, I got the same deal from OG as well, so we can share files
Yes there is a way for that Peter, if you saved the map from before.
Run Log Menu (which is really a tab at the bottom ), select Create GPS Track Map. On the next screen, "STEP 1" button should be "SELECT/CREATE GPS MAP", select that. The next window that opens there should be a button on the middle right-hand for "Open Different Lap File." Click on that one and it will take you to all the lap files you saved from before, including segments created and so forth. That way you can compare you run logs based on the same lap file with the same segment points on the map.
I hope this helps. Btw, RacePak support is truly awesome. If you call them up, they can remote into your computer and show you live on the screen how to do various tasks with the Datalink software.
Cheers,
Fatih
Old 09-08-2009, 10:59 PM
That works, but the VIR 2008 file I got does not have segments. Is there a standard file out there with segments. You can email it to pnk at alum. MITdotEDU (please note the funny spacing to throw off bots).
Old 09-08-2009, 11:32 PM
FTS's Avatar
FTS FTS is offline
FTS
I sent two files to you Peter.
Cheers,
Fatih
Old 09-09-2009, 09:30 AM
N Fotouhi's Avatar
N Fotouhi
Originally Posted by Imprezivblue View Post
I had a great time at my first ever DE. Nader did a wonderful job instructing me - our personalities just clicked. He challenged me to try different lines, brake later, and be more aggressive. I went out with him in white/blue to understand tracking out better at Nascar and Southbend. I'm an autoxer - we don't shift or deal with any traffic so it was a completely different experience. Mike trusted me with his "baby" for the weekend and I was thankful. I thoroughly enjoyed our classroom session as well. If only my engineering professors only had that much of a sense of humor in college! I will definitely be back out at some point. I put 311 track miles on Mike's car.
As usual I am several days late and few $$$ short. You did a great job. Look forward to seeing you continue with another expensive hobby. Save the street tires for Mike next time. That is about his speed
Old 09-09-2009, 09:54 AM
N Fotouhi's Avatar
N Fotouhi
Thanks to all for a well run event. Although I still find not driving much this year still shows in my inconsistent driving, I think I am starting to get more comfortable. The car seems fine after changing the broken motor mounts. I did not put as many miles on as others because I corded a tire on Friday due to understeer into left hook and not wanting to use the tires I was saving for October. However, I flipped the tire and got a few more sessions, some working on trying to get more speed through hog pen and T2-3-4.
Old 09-09-2009, 10:02 AM
Nader,
It was fun practicing NACSCAR pit-stop style tire changes with you!
