SC head Light question - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » SC head Light question
Old 02-11-2021, 09:03 PM
Tito
86911TLCAB
Default SC head Light question
I have always liked the original sugar scoop sealed beam light look on the sc. but the light is not very good and age is only making it harder to drive at night. I am considering new sealed beams and I have seen some 7 inch lights which are set up to use led light bulbs. Has anyone tried to use a set of these on 78-89 911. Any info appreciated. Thanks
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 02-11-2021, 09:08 PM
You can get a drop in with an H4 bulb. You'll need the special relay as well. It's quite bright that way.
No experience with the LED version.
Old 02-12-2021, 10:23 AM
rothaus's Avatar
rothaus rothaus is offline
If you like the sugar scoop headlights the best way is to replace the sealed beams with a good set of 7" LED inserts. I don't sell them any more, but they are still available from other companies. Search for 7" LED headlights A0101. They use them in motorcycles.
There are cheaper stuff out there but they are not as good.
This is what light you will have, low beam
High beam
Don't do H4 and put LED bulbs in there, they don't work with the reflectors and lenses, and send the light everywhere and you will blind oncoming traffic.
Here is what the LED inserts look like installed in sugar scoops
I also always recommend to install a relay kit regardless.
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1984 911 Targa, 3.6L
1982 911 SC
1978 1303 Kaefer Cabrio
1976 914
1971 911T - Current Project
Old 02-12-2021, 11:16 AM
High beam
Cheers
Engelbert
are these DOT approved? Beck in the day I had issues at one inspection station w/H1s since they weren’t DOT.
Old 02-12-2021, 11:31 AM
Sorry. I should have been more clear. What I dropped in was lenses and bulbs. So I guess the pattern was good to not shine in people's eyes. I took them out and put in the Euro version with painted rings. I moved those to my 944 which hasn't seen darkness in years.
1983 911 SC Targa - 1990 944 S2 - Past: 1986 944 n/a - "Doublemint"
"Every one drives to DE but few fly to flight school." - Vicegrip
"Sometimes arguing/reasoning w/Steve is like looking at a compass while having a 2lb magnet in your pocket." - }{arlequin
Old 02-12-2021, 01:07 PM
I have a set of H4 housings and bulbs from my 914, I'm going LED since I have pop-ups and it doesn't matter what they look like when they are down.
Let me know if you're interested. They look like normal 7" headlights. I'd put a relay in to be safe though.
'73 914 2.0 (2.7/6 conversion in progress)
'02 S6 Avant
'99.5 A4 2.8QT
'65 Falcon 80
Old 02-12-2021, 05:29 PM
Tito
86911TLCAB
Is this what you mean. https://www.amazon.com/Bagger-Brothe.../dp/B01AAFRDYK
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 02-12-2021, 05:30 PM
Tito
86911TLCAB
Or. https://www.amazon.com/SUNPIE-Headli...18LXCS0C&psc=1
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 02-12-2021, 06:28 PM
rothaus's Avatar
These are the good ones. There are a lot cheap copies out there. Make sure they have the DOT mark on the lens.
https://www.ebay.com/itm/39303745723...BoCFt0QAvD_BwE
2012 Boxster S
2006 Cayenne S
1986 944 The Beater
1982 911 SC
1976 914
Old 02-12-2021, 06:51 PM
Tito
86911TLCAB
Great thanks. Will do some research. All the help appreciated.
Jim thanks I think the h4 s have the different ring and I want to keep the original scoop lights. I actually have a set of H4s also but holding them in case this doesn’t work out.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
