rusted new wheel studs
I installed new wheel studs on my CS, washed the car and one week later I noticed both the studs and nuts are rusted I don't want to paint them nor spray with a lubricant as this might effect torque specs. I'm waiting to hear back from the supplier. Anyone else have this issue? Thanks.
Sure all the time. I paint the wheel nuts once a year, and the studs when needed. Best to paint nuts on a separate stud/bolt so no build up on threads. Will also lessen effect on painted stud threads.
Looks like you need to replace them with the proper length so they don't stick out so far and the eyesore rust will not be an issue...
Otherwise look into something that has some anti-corrosion zinc plating on both the studs and the nuts like these http://www.rennline.com/Competition-...waAuW4EALw_wcB.
Steve Potomac PCA Co-CI(retired) 89 944 Turbo Race car 85.5 944 NA son's 2015/2019/2020 944Cup and PCA Nat'l Champ racecar 94 968 1 of 11 Iris blue coupes 92 968 1 of 2 Tahoe Blue Cabriolets 98 993 C2S w/Aerokit II 77 911S Vintage race car project 70 Boss 302 86 Mustang SVO 08 F250 SD Diesel 15 Audi SQ5 "Noel spun! Noel spun! Don't do anything stupid, Dad." -the boy on the radio on the last lap of NASA race as the second place car spins behind me in T5 at Summit Point. Last edited by TurboPooch; 04-28-2019 at 05:15 PM. |
When I had mine in the shop a few weeks ago they recommended aerosol (spray) graphite after cleaning them. the said it would turn them black and keep them from rusting. Haven't tried yet, but trust them.
John ___________ 00 Boxster S |
It is just flash surface rust. Next time you have the wheels off wipe the studs and nuts down with some water displacement type light lube. "Dry" bike chain lube is real good. Don't spray directly, spray or wet a rag and wipe them down.
Graphite has 0 ability to resist water and prevent rust. it is slippery sheets of carbon, messy but just the ticket for some things. might not be my first reach for studs.
Fuch it -- it's a track car.
Anti-sieze can be helpful in slowing rust but there are differing opinions on its use on wheel studs.
Jim ------ "2017 Central PA SCCA Witch's Rallye - Best Team Costume Award" "2014 Central PA SCCA Witch's Rallye - Best Team Costume Award" White/Green '91 SSM Miata #01 Green '96 911 (993) Carrera #409 Blue '09 911 (997.2) Carrera S Cab Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle) Burnt Orange '75 FJ40 Yellow '19 718 Boxster (wife regretfully sold it to fit 2nd grandchild on the way...) Black '83 911SC Targa (regrettably sold when the second car seat didn't fit) |
My Rennline comp studs develop surface rust. Just clean them up whenever you pull the wheels. I also use graphite lube when reinstalling, but I also don't expect them to prevent the rust.
