Advice on removing rear shock w/stripped hex ('06 E90)
The driver's side rear shock on my 2006 325i is making a clunking noise, which appears to be a problem with the upper mount. The car has about 120K miles on it, so I am just going to replace both rear shocks and the associated mounts. Here's the potential problem:
The upper end of the shock has a female hex (5 mm IIRC) into which I can insert an allen wrench to keep the shock from spinning as I remove the 16 mm nut that holds it in the upper mount. It looks like this . . . That hole on the passenger side shock is stripped. So, putting an allen wrench in there does nothing to stop the shock from spinning when I turn the nut. Any advice on how to deal with this? I haven't tried anything yet, but I'm thinking about cutting away the dust cover and trying to clamp vice grip pliers on the rod. As I plan to replace the shock anyway, if I do a little damage that should not be a problem. I figure the night before I do the work I can spray some penetrating lube on the 16 mm nut. Any other ideas?
2015 Cayman GTS 2021 Jetta R-line 2016 F-250 Formerly owned Porsche/BMW: 1986 944 Turbo 2006 325i 2000 911 1987 924S 1999 Boxster 1986 944 |
If I could weld, I could weld something on top to grab onto, but I can't weld. If I run into trouble with my other attempts, I might look for someone to try that.
Vice grips on the rod, impact wrench on the nut - zap it right off.
Jeff S '14 991.1 Carrera S Coupe '13 958 Cayenne GTS '11 997.2 Carrera S Cab '09 987.2 Cayman S '12 Audi TT-RS '05.5 Audi S4 '20 GMC Tow Beast '03 986 Boxster Base (kid #3) |
That just sounds fuching painful! Wasn't this done at Gitmo?
So, a little enhanced interrogation is in order?
How you going to slide the socket on the nut if you have grips on the rod? Vicegrip on the rod near the tip. run the nut up to the vicegrip using an open or box wrench then move the vicegrips to under the nut and finish cranking the nut up through the beavered threads and off.
If, following vicegrips most excellent advice, the 16mm nut is hard to spin off errrr up...than hit it with a torch and spray plain old water and go again.
Don't burn down the barn m'kay?
Josh Simonds 07' 997.1 Atlas Black "this ain't tennis, I suggest you figure it out if you plan on doing this sport" |
Torture is fuching hysterical, know any good rape jokes?
That works too! Less fumbling around in tight confines.
