#91
Congrats Chris!!
#92
Nice Install! I am jealous. Can't wait till I can get mine installed.
#93
First weekend using the lift to do actual work. I was happy to see two things - first, with a 10' 6" ceiling, you can get a regular car pretty high. Here's my son working on his Maxima. He's 6' 2": The other thing is that at full height, my high lift garage door opens beautifully:
#94
That's sure a sweet Maxima...
#95
Nice job Jazz!
Do you happen to know how deep the floor anchor bolts needed to be drilled?
#96
BTW, when I started looking into the lift, there were three main benefits I thought I'd get:
1. The most obvious: ease of doing shit under the car. Self explanatory. 2. No more up-down-up-down so easier on my now middle aged joints. 3. Time - being able to wheel the toolbox under the car to work would save time. Turns out - it does in fact save a shitload to time. Seriously, it's awesome. After using the lift for a weekend, I was surprised by a couple other benefits: 4. Less effort - sort of the same as #1, but I didn't really think about it at first. That picture of my son in the last post? He's removing an oxygen sensor from the lower exhaust. It was rusted in but good. An O2 sensor socket + 1/2" breaker bar and the ability to put your body weight into it = removed in 5 mins. Doing that while laying on the ground usually results in what looks like me doing some sort of idiotic pull ups while sliding across the garage floor. 5. Significantly less dirty. No more laying on the ground so no more shirts and pants covered in general garage dirt/grass/oil/grime. You can see in the picture next to my son there's a 20 gal oil drain with telescoping neck. Need to drain something? Raise it to the right height and drain - no splashing or dripping everywhere. Get a little on the floor? Easy to wipe up or mop up quickly no matter the size of the spill. Unless there's a really nasty project I can wrench all day, take off my gloves and wash my hands at the end and feel like a normal human being.
#97
4 inches.
#98
Man that looks awesome, well done. What a huge upgrade.
Another benefit I would imagine is improved access to stuff in the center of the car, like exhaust, prop shaft, etc. where on a scissor lift it's a gymnastics exercise to reach them. Is that really all the slab depth required for a 2 post? For some reason I thought they needed thicker than normal suburban garage depth. Just curious, what sort of bolts are used in this application. I'd imagine something that mushrooms at the bottom, expanding into the hole so it doesn't pull out?
#99
I had someone stop by with their car and a question. I spent some time and figured out what was wrong and what was needed to make it right. I carefully went over the steps and tools needed to do the work and then there was this long pause. I had to break it to him that 1. There was 4/5ths of a car on the lift. 2. There was a car under the lift. 3. there was a car sideways in front of the other two car in the shop. 4. There was a car in the driveway. 5. He was welcome to my jack and tools and I might even come out now and then to talk to the feet and legs sticking out but I no longer crawl under cars.
http://vimeo.com/29896988 “Those that can make you believe in absurdities can make you commit atrocities.” Voltaire. "There is grandeur in this view of life...." Darwin. The mountains are calling and I must go. “The earth has music for those who listen” Shakespeare. You Matter. (Until you multiply yourself times the speed of light squared. Then you Energy) “We’ve got lots of theories, we just don’t have the evidence’. Last edited by Vicegrip; 03-28-2016 at 03:07 PM. |
#100
The most important aspect for a two post is not the slab cracking or shifting it is not having anchor pull out. Good concrete and good install methods is good enough. Almost all automotive lift failures are due to human error. Very few failures of the type people conjure up in their minds. I like to have rebar set 18" on center along with the standard construction mesh embedded in all slabs garage or not. Rebar better resists vertical alinment shifting than just mesh . Slab stays flat.
http://vimeo.com/29896988 “Those that can make you believe in absurdities can make you commit atrocities.” Voltaire. "There is grandeur in this view of life...." Darwin. The mountains are calling and I must go. “The earth has music for those who listen” Shakespeare. You Matter. (Until you multiply yourself times the speed of light squared. Then you Energy) “We’ve got lots of theories, we just don’t have the evidence’. Last edited by Vicegrip; 03-28-2016 at 03:23 PM. |
