Porsche & BMW Cars For Sale/Wanted Post For Sale or WTB adds for Porsche & BMW cars here. Strictly moderated. |
FS - 1987 SP2 prep car - multiple wins and podiums
Moving up to Spec Boxster after many years in Cup, GTS1, and SP2, so am selling my SP2 Prepared Car. Also is competitive in GTS1 in NASA as is with no mods or weight changes. Car is located in the Northern Virginia/Washington DC area
Multiple race wins in GTS1 and Several SP2 Wins and Podiums in previous years. This car is 100 percent turnkey ready to race tomorrow. Has antique plates and can be test driven right now. No assembly or work needed other than a new sub-belt as the current Schroth sub belt expired in 2017. Rest of the other 4 belts expire 2018. Cosmetically Fair - no major dents/dings, rust. Paint in fair condition. Shines up ok but doesn't hold it well. Usual road gravel rash on nose/hood from 10 years of track use. Car information: Logbooks: Has CURRENT 2017 logbooks from PCA, NASA and SCCA Specs: 1987 944 Tub Configured for SP2 Prep class - races at 2750 minimum weight Car weighs 2600 pounds with 1/2 tank of fuel, Fikses, and no driver 1.5" .0200 Piper Chromoly Cage -PCA, SCCA, NASA Legal and certified Motor: 1988 2.5 Block w/Darden Sleeves and Mahle 944 pistons ('88 compression ratio) Fresh timing and balance shaft belts 8/17 Approx 20 hours on engine since new (6 weekends) No (ZERO) leaks Excellent compression and leakdown numbers Good power - Fresh BEHE tune 8/17. Can provide dyno sheets from September to serious buyers but it is comparable to class leaders AC Delete MSDS Ceramic coated header 2.5" exhaust Spec Aluminum Flywheel Upgraded clutch New 968 Radiator 8/17 968 Oil Cooler All hoses cooling and oil hoses in excellent condition Power Steering - new cooler 8/17 New OEM steering rack 8/17 (Porsche re-built -not 3rd party) Braille Battery - 9 lbs - New 8/17 Upgraded Billet Fuel Rail Suspension and Brakes: Fabcar A-Arms Big Red calipers/rotors front w PFC 08's (60% life left) Front rotors good for another season. 944 Turbo calipers rear (Hawk 60s with 75% life left) Rear rotors 75% life left ABS - Fully Functional. Factory option in this chassis Racer's Edge Spherical Bearings/solid bushings/caster blocks etc. in all locations JRZ remote reservoir double adjustable shocks/struts front and rear Tarret Front and Rear adjustable bars with the Tarret adjustable drop links Ground Control Camber Plates Hypercoils 450 and 600 front/rear Other KLA Strut Brace New SFI Windown Net 2017 Right Side Net Additional Oil Temp and A/F Ratio gauges Harry Glass Fiberglass Nose with custom ducting for radiator, oil cooler, brakes. Removable in seconds with Dzuz fasteners GT Racing Fiberglass rear bumper Lexan rear hatch - new 6/17 so it's perfectly clear - no fading/scatching Seatback brace brackets are installed on the cage. I believe I have the Brey Krause brace somewhere in the garage. Trans: 1988 924S Trans with short 5th gear (same as 944 but without speedo drive) Fresh Guard LSD - 6 weekends since rebuild 4:30 Ring and Pinion: NOTE - this is not the 4:11 out of the 924 Turbo. It is the real McCoy 4:30 unicorn. Built by Charley Moore at Intersport. Weltmeister Short-Shift Kit Solid Trans Mount Wheels and Tires (3 sets) 1 Set of 4 17x9 Fikse FM10 3 piece alloys with 245x40 R7s. Purchased new at Radial Tire prior to the Potomac Club Race. 3 sessions on Saturday 1 Set of 4 17x8.5 5 spoke 993 or 996 Porsche OEM wheels. 245x40 R7s with 10-12 sessions on them - still had good speed in them for the Enduro 1 set of 4 17.7 5 spoke 928 Porsche OEM Wheels with 245x40 Hoosier R6 Rains. Tread is excellent and edges of tread blocks still sharp, but are approx 2012 builds. Still soft, no dry rot. Extras/Spares/Parts Etc. include: Spare DME from Ftech9.com. Fully solid state 100% copy of the late 28 PIN DME. Brand new. Spare ABS Computer Power Steering Pump (maybe 2) Alternator Starter Fresh Axle with CV joints 2 hubs with fresh bearings Complete stock rear hatch/glass/spoiler Injectors Full Wiring Harness Various Sensors and Relays May be a set another set of hypercoils Whatever else I have I'll throw in What is not included: Data Logger, Go Pro, Digital Dash, Seat, and Sparco wheel/hub. Will install a factory wheel for delivery or we can discuss the seat/wheel for an additional price. Some pictures are attached. Remainder are at https://944cupsp2racecarforsale.goda...s.com/pictures -->> On a note for locals to this board - guaranteed to lap Pagonis at every race Asking $12,500 OBO. Can separate out some items such as wheels if needed. marks.matt@yahoo.com
2006 944 Supercup Champion Last edited by mattmarks; 12-06-2017 at 11:21 PM. Reason: Adding Images |
Ha! just saw the CL ad and was wondering whose it was!
Moved this to the correct thread
2006 944 Supercup Champion |
Full set of pictures is at https://944cupsp2racecarforsale.goda...s.com/pictures
Ebay Auction is here: https://www.ebay.com/itm/26337060998...84.m1558.l2649
Sold to a Green student in Richmond. New boxster being picked up on Saturday for my Spec Boxster build.
Note - Green student will still be faster than Pagonis
I wish you well with the great car you just purchased from Matt. I'm sure you'll have as much fun with it as Matt had. Dear Matt, I retract my apology from the last race. Note to Self, Don't stay away from Dorki for extended periods....else you'll miss stuff.....
Awesome! Maybe they will land me as an instructor in 2018. I instructed Matt at Watkins Glen in this car when it was bone stock and had it's original 16v engine.
Mark Francis OG Racing: Proud Sponsor of the Potomac Region DE Program 93 964 C2, Polar Silver 89 944 S2, Baltic Blue 86 944, Garnett Red (son's) |
[QUOTE=HoodPin;597991]Dear Green Student,
I wish you well with the great car you just purchased from Matt. I'm sure you'll have as much fun with it as Matt had. Dear Matt, I retract my apology from the last race. Note to Self, Don't stay away from Dorki for extended periods....else you'll miss stuff.....[/QUOTE Hard to retract that from a lap down. hhahahahahahahhaaa I still need to cut up that video and post it.
