e36 clutch pedal dropped to floor - Page 3 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > BMW Technical Discussions » e36 clutch pedal dropped to floor
Old 02-04-2018, 12:56 PM
LPM911's Avatar
LPM911 LPM911 is offline
LPM911
No luck fishing it out with the magnet yet. However, while I was in there, I noticed I can wobble the clutch fork a lot more than I expected. Is that normal? Using my finger I can push it up and down, side to side, back and forth with no resistance.
Lane
'93 RS America | '03 M3 | '02 325iT | '98 328is
Old 02-04-2018, 06:21 PM
mlytle mlytle is offline
Freeloader
mlytle
iirc, if it is the piston you are fishing for...think it is stainless steel. magnet ain't gonna do much good.
yes, fork does have a little play in it. it is just around the throwout bearing in the middle and only held by a small spring clip on the side opposite the slave.
Marshall
75 M2
97 M3
Old 02-05-2018, 10:41 AM
LPM911's Avatar
LPM911
The replacement piston stuck to the magnet, so I had assumed that the old part was that way too. Found some pictures on the internet and have a better picture of whats in there. Good to know that some play in the fork is expected, but still need to get that piston out. Might just turn into a clutch job WYIT.
Lane
Old 02-05-2018, 11:15 AM
Tito
86911TLCAB
Lane, if you look through the thread below there is a picture of the inside of the bellhousing, the clutch fork and the pin.
https://dorkiphus.net/porsche/showthread.php?t=37205
When I first got my 97 e36 I could not push the clutch all the way down. when I did I get some very horrible grinding feeling. Not fully understanding the potential issues I figured it was just the clutch itself. When I removed the trans, I found the little plastic fork pin (picture in the thread) was broken and the fork was no longer connected on the passenger side of the bellhousing. so I am not sure what was really happening when I pushed the clutch pedal in.
So there is some movement, but I don't think it should move real free unless the fork pin is broken (apparently a common problem--they now sell a brass pin). If you are able to move that around freely, I would venture your pin is broken and the passenger side of the clutch fork is not connected to the housing.
when I did mine I swapped out the shifter bushings also...the car shifts like it was new.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 02-05-2018, 08:55 PM
Freeloader
mlytle
if the plastic pin is broken, you would probably be able to spin the clutch fork around since it would not be anchored on that side.
i hope it does not turn into a clutch job! if it seems like it might be going that way, you could just get as far as loosening the bellhousing bolts enough to slide the trans back a half inch..enough to get the pin out.
maybe call around to some autopart stores to see if any have a loaner borescope tool that will let you look around in there.
Marshall
75 M2
97 M3
Old 02-05-2018, 09:59 PM
LPM911's Avatar
LPM911
I think tito nailed it, I think the clutch fork pin is busted or its otherwise become disconnected on that end. I could stick my finger in the cup on the clutch fork and pull it directly towards the side of the bell housing away from the fork pin. I have a video where you can hear me clanging it all over the place.
Lane
Old 02-06-2018, 08:17 AM
Tito
86911TLCAB
It is likely broken. If it were me I would get the car home and prep for a tranny pull. If you decide to do the clutch, and don't want to buy a new dual mass friction flywheel, I was able to have mine resurfaced for about 120 bucks.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
