Miscellaneous Discussions Off Topic (OT) items that really don't fit into any other Category |
Mechanics? Who do you recommend?
Reaching out because I am sick of dealing with an oil leak. I spent 2 days on it and just done really.
The leak is coming from the lower cover on the passengers side, replaced the upper gasket and put on Rennline billet valve covers on the lowers. Torqued to specs, all that said still have a leak and like I said, done. I had factory turbo lowers on it before the Rennline. The Rennline did take care of the drivers side leak, and most of the passengers side but now the leak is coming from the top of the lower cover?!? I heard that some people are talking about using silicone lowers that are 1/16 thick and tighten to 15 inch pounds, installed dry. BUT... I feel like that's a Hail Mary. I could do Wrightwood gaskets and put the turbo covers back on, but.....bitter... Did Charlie retire? Thanks! Bill
“When I was born I was so ugly the doctor slapped my mother.” – Rodney Dangerfield Bill C "aka" Catdaddy - The Catfather - Current: 1980 911sc 2019 Ford Raptor 1987 Mercedes 560sl ------------ Sold: 2011 BMW M3 2000 996 C2-IMS 2 Row, RMS Update 1986.5 928s 1987 944 16v 1973 911t 1969 911t "My first car"!! 1969 Westfalia Bus 1973 Volks Superbeetle |
Charlie is still around as far as I know. Probably need to take it to their Ashburn location, though. Other options closer in are ASG and Autobahn. Autobahn's lead mechanic has decades of experience.
Can you pin point what is exactly leaking?
- Is it the rocker shafts - Is it the valve cover You will know if its the shafts as the cavity between the rockers will be wet. The fix here is RSR seals. If its the valve cover and you have brand new Rennline covers then you know that surface is good, but how is the cam tower surface? Silicone covers are the only thing on my SC drivers side that will prevent a leak. I tried both stock and stock with the silicone bead. Both allowed a leak because some smart guy marred the cam tower. Once the silicone gasket was put on, its been dry for 1,000+ miles. |
Taylor Chapman did my supplied silicone gaskets from Pelican back in the day when I converted to the Turbo covers. I can't recall the maker of the gasket, but it was whatever was offered back in 2007-8.
I never had any leak issues. Maybe hit him up?
Rob T. 2006 Carrera S 2013 Cayenne GTS |
Sure that the leak is not coming from an oil return tube?
The triangle of death is sneaky, can leak from there and make you think it’s from somewhere else.
'64 356 SC '73 914 2.0 (2.8/6 conversion in progress) '65 Falcon 80 ‘19 SQ5 Gone but not forgotten: '02 S6 Avant - trans blew, but rebuilt as a 6-speed by new owner '99.5 A4 2.8QT - tree fell on it after 20 years ‘74 MB 280C - traded for paint/rust repair/6-conversion mods on the 914 |
Charlie is semi-retired (but the best choice for fixing things like this). Still at Intersport but also is working on improving his golf game (which is better than mine). I'd call Intersport in Ashburn and see what they can do for you. Sometimes it works best on timing for Charlie to look at it and have him tell one of the other folks at Intersport what to do.
Jim ------ "2017 Central PA SCCA Witch's Rallye - Best Team Costume Award" "2014 Central PA SCCA Witch's Rallye - Best Team Costume Award" White/Green '91 SSM Miata #01 Green '96 911 (993) Carrera #409 Blue '09 911 (997.2) Carrera S Cab Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle) Burnt Orange '75 FJ40 Yellow '19 718 Boxster (wife regretfully sold it to fit 2nd grandchild on the way...) Black '83 911SC Targa (regrettably sold when the second car seat didn't fit) |
“When I was born I was so ugly the doctor slapped my mother.” – Rodney Dangerfield Bill C "aka" Catdaddy - The Catfather - Current: 1980 911sc 2019 Ford Raptor 1987 Mercedes 560sl ------------ Sold: 2011 BMW M3 2000 996 C2-IMS 2 Row, RMS Update 1986.5 928s 1987 944 16v 1973 911t 1969 911t "My first car"!! 1969 Westfalia Bus 1973 Volks Superbeetle Last edited by catron1; 06-06-2023 at 06:35 PM. |
Thanks!!!
Return tubes are dry.
