I've seen a few with a Supercharger added for more hp.. Some were reliable, some weren't.
#12
The reliable conversions tend to be the ones that don't get driven much.......
#13
I'm struggling to remember a turbo conversion that lasted a whole DE weekend. I have driven two supercharged conversions to failure in one session each. Neither were 20 year old cars.
#14
You could get good power with a 3.2 rebuild to 3.4 or 3.5...that's another option. It'd look the same but pack an additional 50hp punch.
#15
I had a student with a supercharged 993 at VIR. It lasted the weekend with no problems, but I don't think the car ever got over 90 MPH (older driver).
#16
You da' man! What kind of cheapest engine management system were you using, or which you would recommend? Thanks. |
#17
So, the cheapest on any low boost conversion- use a pressure-rising fuel regulator on the return side of the fuel rail and retarding the base ignition timing manually by setting the distributor. This IS the cheapest fuel/ignition "management" method, its usually good enough for hard thrashing on street and 1/4-mile runs, but perfect example of not good enough for HPDE use. Next step up is the get a MSD(or some other brand) boost ignition retard device and secondary fuel injector(s) which was very popular for 930/C2 Turbo cars with CIS(I think ANDIAL started this trend on 930's). When set properly, this then is good enough for HPDE. Edit: Next step up is to replace stock fuel injectors with 36-lb or 42-lb or up to 72-lb injectors, add Bosch Motorsport fuel pump, and custom programmed EPROM chip for stock DME. This method is same level as OEM and RUF. What I really recommend and want to do is a standalone ECU such as Motec, Haltech, Bosch Motorsport and dyno tune on a built engine. But this'd then turn a 1-week shop project to 6 months+ project and cost approach or at 6 digits including the engine build. Due to the extensive nature of this level of work only ~5% of the conversions were built to this level. Suitable for street, HPDE, club and pro racing. Seasoned companies such as TPC, IMA, Intersport, Jerry Woods, Kelly-Moss, AJR just to name a few have done such conversions with great success. Last edited by TomChan; 08-30-2017 at 05:48 PM. Reason: Missed a step, see edit |
#18
Cheap = Motor blows up. Right = Budget blows up. Gonzo's Re-manufactured Engine Non-stock Accessories Development Enterprise. GRENADE.inc
#19
#20
Hey Tom,
Can't the oil gravity drain into the drain plug or tap into the bottom of the chain housing cover? A electric oil pump sounds sketchy. Chris |
