#41
The last set of 97's I had lasted forever it seemed but I went back to Pagid Orange because I'd used them before and less dust. We'll see.
Dr. K thanks for the link to Pelican. That's quit a set up. I may just cut up my shop vac and save some money
Hunt 611racing.com OG Racing Team Vimeo https://www.youtube.com/user/Streak986 1999 SPB #611 2004 Wrangler “That’s how people like you work. Your ego is so out of whack that it will do what ever it can to protect itself. And people with a messed up ego can do these mental gymnastics to convince themselves they’re awesome when really they are just douche bags” - Kyle, South Park "If you need to focus maybe you should buy the book and take it home" - MLIN |
#42
#43
Hey....you could install a 120V converter in the front trunk, and then run the shop vac in reverse to provide cooling to the brakes. That way you could seal the openings on the airdam and clean up the aerodynamics....
#44
#45
A few points: - My rotors are drilled like Alan's - I think that causes premature cracking. If I could find a flat rotor at the same price I would use that instead. I did have a twice-as-expensive set of slotted's last year, and they lasted about the same before succumbing to wear, but they may have been made of poorer metal. - It seems to be heat related: the cracking is a little worse on the passenger side, behind the oil cooler. - I probably brake too much
Jeff S '14 991.1 Carrera S Coupe '13 958 Cayenne GTS '11 997.2 Carrera S Cab '09 987.2 Cayman S '12 Audi TT-RS '05.5 Audi S4 '20 GMC Tow Beast '03 986 Boxster Base (kid #3) |
#46
Well......it appears I've left my DumbAssGene out in public again. Thanks to one Dorki who politely sent me a PM, and another Dorki who recently introduced me to www.livermoreperformance.com, I'm now a bit more edumacated about the Hawk line of performance brake pads. It appears there is no such thing as an HPS+ pad. It also appears that I've been using Hawk HPS pads, which is their least performance brake pad. Dohhhh....
I've still got some pad "inventory" to work thru. But I guess I'm going to have to start shopping for something better. Will probably continue using the HPS pads for street use, and start switching to something better for track days. I've just ordered some PF97's which should be delivered tomorrow. Lesson learned.......
#47
Tony -- be careful, if you brake harder you will lose all that momentum you carry though the corners so well!
#48
Hawks HPS = High Performance Street; HP+ = High Performance Street/Track. Hawk Blue = enduro type track pad. The blues work well on the track, but squeal a lot.
I cracked my S4 front rotors this spring using PF97 pads. PF97's work well, but rely too much on iron content, which equals sparks out of the wheels while braking, rust stains on the driveway after rains and burnt-in pad dust residue on the wheels which requires an abrasive pad to remove. And cost more too. The bad out weighs the good = fail.
Kevin Oyler '88 944 Turbo S "Don't let a few facts get in the way of a good story" |
#49
Thanks for the info. As far as the dust/iron, I'll just plan to keep the airtank full, and try to blow off as much as possible during the weekend. PF97's & Hawk Blues were the only thing I could get on short notice (OG Racing). Have been advised that PF97 are easier on rotors than Hawk Blues. Fortunately, none of our wheels are concours quality....
#50
Enough talk about pads. Where can I get a spray-painted avatar???
'96 993 - polar silver '06 Acura TL (manual gearbox winter beater) - white diamond pearl '17 Macan GTS - agate gray (SOLD) Looking for E39 BMW M5 |
