Wheel studs
Hey all,
I need to replace lug bolts soon and wanted to poll if it was worth it going to studs. I don't have issues getting the wheel on and off with the lug bolts but from a longevity standpoint is it recommended to go studs to save the aluminum threads in the hub? If so, what is a reputable vendor for wheel studs? MSI pops up often from my reading. Nick |
My opinion: If you track the car it is a good idea. If you only need to fuch with wheels/ tires once a year or so then it may not be worth it.
Yes, this car will see the track often so a lot of on and off with the wheels.
If it makes a difference, the car is a 987.2 cayman. |
^^ x2
If tracked a bunch, and different wheels will be used, the studs make wheel changes much easier. In addition to frequent pad changes, and brake bleeding.
I've had MSI studs on a couple of cars including 987.2 Cayman. Pricey but haven't broken one yet.
_______ Brian '71 T '72 E '80 Weissach SC '94 C2 '05 996 GT3 CUP '09 White Winged Cayman S (Hers, all hers!) '11 GTS/C4S Donuts '15 Boxster S #Blubyu |
FWIW, I believe that the wheel hubs on the modern cars are steel, not aluminum. Hence, less worries about wear on the threads. This is for the wheel mounting lug bolts/studs.
Roger that, I am going to be going with studs. Any insight on the shouldered design vs non shouldered design?
https://www.tarett.com/items/986-987...ts1-detail.htm https://www.teambgb.com/product-p/msi.htm |
John V 2024 BMW G87 ///M2 (Next 444) 2021 Toyota Supra GR (The Bupra, Other 444) 2016 BMW M235 2015 Porsche Cayenne Diesel 2007 Cayman S, #444 2013 Golf R 2012 BWM x5 2017 Mazda MX-5 Club 3 time DE Parade Lap Champion #BestInstructorEver - Unknown |
IMHO, the bullet nose version are much gentler on wheels going on & off, and are also less prone to cross threading the nuts. You are hand starting them, aren't you?
Make sure you measure twice and purchase once. You want the length to be able to accommodate any potential wheels in your repertoire; not all wheels have the same wheel center thickness, plus you want to account for any potential spacers.
Barry 18 Carrera cab 15 Macan S |
