Local ceramic (or other protective) coating for headers?
I've got a fairly rare set of long tube headers from Sweden on my old Volvo 240 DD/clunker. They're mild steel, and starting to show a decent amount of surface rust. I'd like to get them coated to protect them from further corrosion (performance really isn't a concern on my ~70HP 240), but I'd like to avoid the time and extra cost that shipping to a place like Jet Hot would add. Is there anywhere local-ish that does this kind of work?
1989 951, Leinengrau Metallic 1990 M3, Sterlingsilber Metallic 1991 Volvo 245SE, White Pearl Metallic |
https://www.ascoweb.com/
No personal exp with ASCO but my 2 experiences with Jet Hot were underwhelming
Thanks. I’ll give them a call.
Interesting as I've had several items done by JETHOT and all worked out well.
I have used ASCO as well for some powder coating but nothing related to high-temp.
RGruppe #180 PCA Potomac + 35yrs So many cars..so little time!! |
If you can find a local company you might take a look at cerakote. There is a high temp air dry version you don’t have to bake. Just mix and spray on your cleaned part.
Current 07 Mini Copper S 99 Dodge Viper ACR 65 Shelby 427 SC 07 Ducati 1098 17 Alfa Giulia Quadrifoglio Projects 86 "Backdate" 911 2.8 RSR 73 911 T Targa (Sold) |
Nether setup had much of any change in the thermal properties before and after that I could detect.
