Boxster Caliper removal???
How do I remove the calipers from a 2001 Boxster S? The brake line going into the caliper seems to be the palce but the bolt does not want to turn and I do not want to force it. I have bled all the lines.
There are 2 large, long allen head bolts on the back of the caliper, that connect it to the hub bracket.
Here's a website with some info/pics: http://www.bombaydigital.com/boxster...change_rotors/
Also, there's a know corrosion issue, that may cause some bolt binding if the bolts were reused during a prior rotor change. OEM bolts come pre-coated with an anti-sieze. Recommended to replace bolts if caliper is removed. But if reused, should put some good quality anti-sieze compound on the threads. If they don't want to budge, you may try soaking with anti-corrosion spray for a while. Otherwise, heating with a torch may be needed.
Thanks Tony. I mean remove completely. I am selling the calipers. The caliper bolts are lose. I need to know how to diconnect the brake line. |
Alternative, cut the brake tubing and use a socket or box wrench. (6-point would be more effective than 12 point).
Vise grips can work well, too (assuming you gon't care about chewing up the nut on the brake line a little).
Hope your part-out is going well!
If the flare nut wrench is bending open and rounding off the nut clamp it tight with some vice grips. A little heat on the cailper helps too.
IF car is going to crusher just cut it and be done. Once off deal with it if needed.
Do you have a buyer for them? If not I'm interested
Bernard 84 VW Rabbit GTI 97 VW GTI VR6 14 VW Touareg TDI 24 Mini Cooper JCW |
Good point. I will get out my saw and use a closed end wrench. Thanks. |
