i need airbag light help asap!
after piper motorsport installed my omp track seats, i was surprised that lap belt buckles "worked", meaning the light and alarm went off when buckled
however, the PWS sensor and the seat mounted side airbag fault is still an issue i need this issue solved so i can get my stupid va safety sticker tysons porsche would not do it who do we know that can, and is willing to, adjust the programming so the car knows it has seats without airbags and without passenger weight sensors? thanks otto
Otto #906 2021 Boxster 25 2014 Cayman S 2012 Cayman S 2006 Boxster S |
ASG or Intersport can do this for you.
95 993 16 GTI 02 BMW Spec E46 #27 01 Boxster 86 944- AER/Chump #33 20 F250 Tremor |
Otto,
On my 987 Boxster, I turned the warnings & lights off with a Durametric. I don’t know if that’s possible on a 981. But I have durametric pro if you want to give it a try. Mark
Mark S 2006 Cayman S 2005 Boxster S - G Stock #667 1978 Triumph Spitfire 2006 Harley Night Rod |
I haven’t checked recently but last year it was not possible on a 981 with a Durametric. Also, I’m not sure whether ASG will do this service due to liability concerns. Intersport would be worth calling.
they expect the light to come one when the engine is started, then go off once the system does its system test
Hey Otto - Can it be disabled with a PIWIS? If so, I might be able to help..
Check the inter webs for the DIY on running a jumper wire from one of the other lights.....
Time for a Montana LLC
Jim ------ "2017 Central PA SCCA Witch's Rallye - Best Team Costume Award" "2014 Central PA SCCA Witch's Rallye - Best Team Costume Award" White/Green '91 SSM Miata #01 Green '96 911 (993) Carrera #409 Blue '09 911 (997.2) Carrera S Cab Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle) Burnt Orange '75 FJ40 Yellow '19 718 Boxster (wife regretfully sold it to fit 2nd grandchild on the way...) Black '83 911SC Targa (regrettably sold when the second car seat didn't fit) |
Black electrical tape
Scott Bresnahan Purcellville Va. http://agent.allstate.com/SBresnahan/Welcome 2014 GTB1 World Champion 8 Time National DE champion 88 911 Cup 13 Boxster S 1969 Saab Sonett 2005 Cayenne 2013 Cayenne 2014 F150 Hurricane race trailer with A/C 05 Cup car 02 Koni 996 |
