#31
I like inventions new project. Are you buy ceramic seals lubrication water?? simile oil configurations only change oil too water? Water lubrication only going , when engine is hot. This few first are without lubrication.Ceraamic seal are wery nice work at hi presure water cleaning..... Other seals are possible proposal- other eginers too like make inventions Angel |
#32
In large scale are better see advantages or disadvantages
Regards Andrew |
#33
Animations
For all advocate
Regards |
#34
seals
New steam engine (only one) using in Big Boy locomotive,ships, tractor, or enegy plant. Possible fuel: biomass ,wood,peat, russet coal,coal,ethanol,biooils,oil,hydrogen,biogas,LPG, natural gas,uranium,fusion. bigboy |
#35
Version for small engine air-cooled:
Develop air-cooled(Porsche} half rotate piston : Two big closed bearings,little different seals: (3D not enough, two picture for good explain ) Plus some fin inside "piston" and good air vent . Or two small bearings ..... Regards Andrew |
#36
Intake window ,height 20 mm , long~~80 mm . S1=16 cm^2
S piston intake (diam. 62mm) are 30 cm^2 In other side of piston are possible made another window.But ,2 X 16 =32 cm^2--There is greatest section than crush intake piston.So, there is needless after opposite part this window executable. Accidentally no need for car new system of power steering? Sound |
#37
Some other interesting mutation half rotate- engine
With torsion bar, end hydraulic absorber. If need change McPherson , next pictures see: Regards Andrew :coffee::coffee: |
#38
Efect:New oscillating dynamo Same in the picture: Are possible 100 pcs in 1 square meter, =~~ 1 KW one meter 1 km ^2 = ~~ 1000 MW ps. sail -boat with this innovation obvious name wave-boat :coffee: In cars are possible electric variable last absorber shock or computer current digital regulated :coffee: How much KW (or HP) power have simile waves? Or, how much this wave eqivalent CO2 in climate change ? What to make countries lack for sea ? If you no like a very cold water in electricity service: Quote:
Or Wave Scanner: resolution e.g. 0,005 dpi I start straightening of sea. Regards Andrew |
#39
Two bulbs in each same coil of stepper.One with diode and capacitor.Turn left-right, left -right.....
http://www.new4stroke.com/stepper.wmv Regards Andrew ps.bulbs 22V 0.05 A |
#40
A Christmas present:
New oscillating stepper engine: Version "Stephenson 3 E" For modifications "old machines" without gears or new car Regards Andrew |
