to girodisc or not to girodisc - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » to girodisc or not to girodisc
Old 04-23-2019, 06:26 AM
RV4Flyer's Avatar
RV4Flyer RV4Flyer is offline
RV4Flyer
Switch out the front caliper bolts to studs since you will be changing pads often. The caliper needs to be removed to change the pads on the 981S.
Certainly personal preference but I run Pagid RS29's on the front and PFC08s on the rear. I like the brake bias it gives me. I also run with the Sebro solid slotted rotors as I am too poor to afford the AP setup.
Mike
14 981 Cayman S
Wall of Dearly Departed Loved Ones
07 987 Cayman S
03 996
86 944
74 914
78 924
Bro Code Rule 43:
When a Bro learns another Bro has been in a traffic accident, they must first ask what condition the car is in.
Old 04-23-2019, 07:32 AM
Fumes's Avatar
Fumes Fumes is offline
He HIT me.
Fumes
not to girodisc
sebro low cost stops the car fine
cal studs or time-serts both work well but those calipers are annoying to deal with
2012 987.2 R (endless build)
2009 997.2 C2S
2012 F-150 (tow)
2013 991.1 C2 (sold)
2013 335i (RIP)
2001 4Runner (left by side of road in Georgia)
1990 Legend LS (RIP)
1988 Toyota 2WD reg cab (donated)
1987 GTi (sold)
1990 (TOM)Celica GTS (RIP)
Old 04-23-2019, 08:20 AM
What options are there for increasing the air flow? More air flow cures many issues for the least amount of $
Old 04-23-2019, 08:25 AM
Chopper Dropper's Avatar
Chopper Dropper
Otto, you are over thinking this again, drive the bloody car first at a couple events, then figure out what you might need!!
Dirk
Co DE Chair, PCA Potomac Region.
1988 911 Targa
1986 944
Old 04-23-2019, 08:52 AM
Fumes's Avatar
He HIT me.
Fumes
Dirk
Except a harness bar, seats, harnesses, HANS. It's the first rule. Be safe.
2009 997.2 C2S
2012 F-150 (tow)
2013 335i (RIP)
1987 GTi (sold)
Old 04-23-2019, 09:07 AM
vranko's Avatar
vranko vranko is offline
vranko has one HoF thread
^ All good advice. Last thing you need is brake upgrades. Drive it as is first with track pads, then slotted rotors, safety, cooling, suspension (bars, shocks) over time. I've switched back to Pagid pads from PFC. PFC 08s were apparently somewhat contributing to my ice pedal issues. Sounds like the newer Caymans don't have this issue so may be able to use more variance in pad brands / materials.
John
John V
2007 Cayman S, #444
2017 Mazda MX-5 Club
2015 Porsche Cayenne Diesel
2013 Golf R
2012 BWM x5
3 time DE Parade Lap Champion
#BestInstructorEver - Unknown
Old 04-23-2019, 01:13 PM
Otto's Avatar
Otto Otto is offline
Otto
finely something i can use
but this also makes me want the stoptech setup, where it is supper easy to change pads from the top of the caliper
if i did get the girodisc, i would still be removing the calipers to change pads, what a pain
Otto
#906
2014 Cayman S
2012 Cayman S - retired
2006 Boxster S
Old 04-23-2019, 01:27 PM
Otto's Avatar
Otto
yeah
been looking at a harness bar as opposed to a bolt in roll bar
not sure which way to go at this point
intend to look more closely at other 981s at the track to see what people have, like and don't like
plan to only drive the car at 80% until i get it all sorted
i may even be driving on the new p-zero street rubber the dealer provided
trying to get a used set of track wheels with the right specs for a 981
no luck at the swap meet
wondering if i can run 19x11et50 on the rear and 19x8.5et50 on the front
i have been learning that the offset is not carved in stone as i had thought, and that each wheel size, 18 vs 19 vs 20, changes the acceptible offset range a bit, generally et+/-5 for each size can still work, but a test fit at speed it needed for certainty
Otto
#906
2014 Cayman S
2006 Boxster S
Old 04-23-2019, 07:13 PM
trytryagain's Avatar
trytryagain
I have a BGB Motorsport harness bar, which has a halo (rollbar). Its pretty good but not as strong as a true half cage. You can check it and other stuff out at https://www.teambgb.com/
Jim C.
1986 911 Targa (Aka "Dusty")
1971 914 (back in the day)
Old 04-24-2019, 06:54 AM
BMAN's Avatar
BMAN BMAN is offline
Cushion Convector
BMAN
I have a set of 18 track wheels from a 987.2 on our 981. Fitment is fine. Tire diameters for the 981 are greater, +/- 1, front and rear IIRC.
Have your tried your 987.2 wheels?
_______
Brian
'72 E
'94 C2
'05 996 GT3 CUP
'11 GTS/C4S Donuts
'15 Boxster S #Blubyu
