polish engineering... hey, no laugh! - Page 7 - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » polish engineering... hey, no laugh!
Old 09-24-2008, 08:07 PM
Feliks's Avatar
Feliks Feliks is offline
Feliks
Why I don't like spring:
Yes, discus about advantages and disadvantages of spring a re start
Some video, what spring of poped can make
http://www.engr.colostate.edu/high_s...pm_3000fps.wmv
http://www.engr.colostate.edu/high_s...pm_1000fps.wmv
I thnik, so pistons valve , and rod eliminate this "play sprig".
Mass too is better solutions.
Regards Andrew
Old 09-25-2008, 11:23 AM
NoPaint NoPaint is offline
NoPaint
Feliks are you making these?
Old 10-12-2008, 06:16 AM
Feliks's Avatar
Feliks
Not, last time I do not like springs and cogged transmission
Farthest development at one pivot stand differential animations, but this time about 180 degrees removed rod. Permutation is possible about 90 degrees definitely too.My be It's help if torque will not have a linear relationship But which setup will be better, as yet, I do not know
To develop simile Torsen torque biasing and traction management too.
Regards Andrew
Old 10-15-2008, 06:04 PM
Feliks's Avatar
Feliks
You see this animations?
Andrew
Old 10-26-2008, 10:58 AM
Feliks's Avatar
Feliks
But it, you know it definitely :
Regards Andrew
Old 11-02-2008, 07:23 AM
Feliks's Avatar
Feliks
You know last time my distaste for transmission cogged ??
Visit Ricardo Company -http://www.ricardo.com/engineeringse...boxengineering I see many problem with it.
My solve: Wind motion my oscillating dynamo packs, without any cogged transmission:
Regards Andrew
Old 11-03-2008, 07:23 AM
Feliks's Avatar
Feliks
But if you no like oscillating dynamo , I have my proposes without this:
Name Beam Dynamo.
Such type of pump has been born for too, that produce electric current from marine waves can .
Under-sea fields with energy?
Regards Andrew
Old 11-04-2008, 08:56 AM
Feliks's Avatar
Feliks
In Beam Dynamo we can change input data using set off pulles.
This pull my story:You know last time my distaste for transmission cogged ??
First principle pulles:
Regards Andrew :smoking: :smoking:
Old 11-05-2008, 08:42 PM
Feliks's Avatar
Feliks
You know , if dreams me diesel helicopter?
Regards Andrew
Old 11-11-2008, 06:40 PM
Feliks's Avatar
Feliks
Big Boy with Stephenson Second engine are going.
Ride it where ?
Andrew
ps Need new electronic valave drive system.
