Problems, Support & BBS Questions Please post board related problems in this section for resolution. We know there are some furballs out there so let hear about them. |
#21
Still can't connect from home, 15 minutes later. Page loads and refreshes from the Michigan server are sub-second.
#22
Seems ok now. Im on verizon fios. Ive been running a tracert when it seems really slow and I get ~45ms, so it seems getting to the physical machine hasn't been my problem. But that doesn't jive w/ what you are seeing. Can you ping the machine from home?
#23
Yup, can ping and everything. Tracert dies at their end but seems to make it to the server host. I've been trying Dorki since 11:30pm and no luck. Access from Michigan was fine (subsecond) but no joy from DC until I got an email that Stephen posted on this thread and tried again. Then it was back to subsecond.
#24
NW DC, Verizon FIOS. Fine now.
#25
see the same issues from time to time. In VA on Fios evenings and in VA on comcast daytime.
#26
McLean VA FIOS. Back to normal this morning. Is the site co-hosted with your pron site??
#27
Perhaps it is a DNS-related issue. Best I can tell, Jazzbass hosts this on godaddy, correct?
If so, when folks are having trouble accessing Dorkiphus, you might want to check to see if you are also having trouble accessing other godaddy sites (just check godaddy.com to start). Other thing to check when you have trouble would be if you can access Dorkiphus without a DNS lookup by entering "http://199.193.245.244" into your browser instead of "http://dorkiphus.net". If the numbers work and the words don't, its a DNS issue. (Of course I don't know how to fix that...)
Jim ------ "2017 Central PA SCCA Witch's Rallye - Best Team Costume Award" "2014 Central PA SCCA Witch's Rallye - Best Team Costume Award" White/Green '91 SSM Miata #01 Green '96 911 (993) Carrera #409 Blue '09 911 (997.2) Carrera S Cab Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle) Burnt Orange '75 FJ40 Yellow '19 718 Boxster (wife regretfully sold it to fit 2nd grandchild on the way...) Black '83 911SC Targa (regrettably sold when the second car seat didn't fit) |
#28
Looks like the problem is a firewall block at the host. Why the block is being put in is the next question.
#29
Germantown as well, FIOS 50Mbps. In the mornings it is fast, evenings after 8 pm it is unbearable.
Cheers, Fatih |
#30
That's it, I'm calling Danica Patrick
